powermaster 9400 starter - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 29th, 06, 06:17 AM Thread Starter
I just aquired a power master 9400 starter from a friend. It doesn't have any instructions with it. It is supposed to hook up to either the 153 or 168 tooth flywheel? I have the samller one. I only see 4 bolt holes in a traight pattern? Does it only bolt up 1 way? I am waiting for a new solenoid to arrive before I try and install it since the car is currently running.
Dave69Z is offline
post #2 of 4 (permalink) Old Jun 29th, 06, 04:24 PM
JohnZ's Avatar
Re: powermaster 9400 starter
The 9400 works with either the 153- or 168-tooth flywheel; that's why it has two pair of mounting holes. You use the inboard pair for the big flywheel, and the outboard pair for the smaller flywheel.
JohnZ
CRG
JohnZ is offline
post #3 of 4 (permalink) Old Jun 29th, 06, 06:46 PM Thread Starter
Thank you thats what I needed to know. Since I don't have the instructions fot the starter.
Dave69Z is offline
post #4 of 4 (permalink) Old Jun 30th, 06, 06:55 AM
Here are the instuctions...
http://www.powermastermotorsports.co..._GMMiniSta.pdf
http://www.powermastermotorsports.co...i_Shim_Kit.pdf
Greg U
undee72Z is offline
Starter issues with Proform starter X33camaro Electrical & Wiring 4 Aug 22nd, 05 08:44 PM
Powermaster 9000 hi-torq mini starter icunjl Engine 2 Aug 1st, 05 12:57 PM
Starter Tech JimM Electrical & Wiring 2 Sep 21st, 04 09:41 AM
starter teeth problem. flywheel grinding Marc Engine 6 Jul 7th, 03 01:53 AM
Powermaster retro starter Jorgen Andersson Tech 2003 0 May 30th, 03 08:47 AM
