69 console gauge problems - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 29th, 06, 08:02 PM Thread Starter
Angry 69 console gauge problems
Hello, I have been tryin to get my gauges to work for 2 days, Iam going crazy by now!!! Can anybody help?? Here we go, I do have the oil gauge working that was easy, and I have the volt meter working, The temp gauge and gas gauge are my problem! The temp will bury the needle when you turn the lights on, that is crazy to me but that's what it does! and in a few seconds the gas needle will start to move to full?? I do not have any volts back at the gas tank, I have been using a test light, to check that. Why would the headlight switch be tied into the gauges? Also when you turn the key on nothing happens at all?? Can you help!!! Jimi
jimi302z28s is offline
post #2 of 4 (permalink) Old Jun 30th, 06, 03:37 AM
Re: 69 console gauge problems
You must have tapped power from the intrument lamp circuit instead of a keyed 12V source. The way the gas gauge is working it sounds like your missing the shunt resistor on the back of the guage.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 4 (permalink) Old Jun 30th, 06, 05:28 AM
Misha
There's a book you can get that explains everything, including a wiring diagram / schematic of the whole she-bang.....sorry for the pun....
It's P/N: GWM-79 in Rick's catalog.
Tells you exactly how to wire-up a complete console guage package, along with RS headlamp info.
Good Luck...
69ss350 is offline
post #4 of 4 (permalink) Old Jun 30th, 06, 07:03 AM Thread Starter
Unhappy Re: 69 console gauge problems
Thanks guys for the reply! I do have the shunt resistor on the temp. and gas gauge, So do you think that when I turn the lights on for the console lamps Iam sending current to the gauges?? Also is there voltage at the wire connector for the sending unit? I put my test light to it and reads nothing, Thanks Jimi
Console gauge harness connectors Amptech Electrical & Wiring 17 Sep 21st, 06 08:50 PM
What parts are needed to convert 69 AT console to 68 4 speed Winch Interiors 0 Sep 19th, 05 06:32 AM
console oil press gauge leaks BAMiller Interiors 13 Aug 18th, 05 06:00 PM
Console Gauge Package - Temp Gauge Question dschribs Electrical & Wiring 2 Nov 5th, 03 01:38 AM
Wiring problems with console fuel gauge Jeff H Tech 2000 1 Nov 15th, 99 04:40 AM
