IN-line Fuse (Choke) - Team Camaro Tech
post #1 of 1 (permalink) Old Jun 30th, 06, 05:35 AM Thread Starter
HI All, Doing some simple wiring and had a question. I Found a 12V switched line for the Choke.(I believe the line it the wire that powered up the Heater hharness which I do not use.) I followed the line back to the mass of wires comming from the harness so I "Assume" that it is fused somewhere. Anyway I don't want to guess as my choke wire runs close to the fuel lines. Would it be OK to put and in-line fuse someweher in the wire to protect the circuit (Even if it is fused at the main block somewhere)? What is a good amperage to run for a choke with no other accessories. Where is the best place in the circuit for the fuse, or does it matter.
Chris
freebird is offline
cooling line route? kencar69 Transmission & Driveline 11 Apr 27th, 06 07:23 AM
Urgent: Rear Brake Line CFunK Brakes, Suspension & Steering 14 Oct 3rd, 05 10:29 PM
where does the vacuum line for the choke go? JTM Engine 10 May 5th, 04 03:33 PM
In line fuse for fuel pump williamsjg Troubleshooting 3 Dec 14th, 03 05:50 AM
Can I convert my 1/4 vent/return line into a 14psi return line for TBI unit??? snflupigus Tech 2000 3 Jun 13th, 01 03:57 PM
