69 console harness questions - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 30th, 06, 04:16 PM Thread Starter
Hello, still tryin to find my problem Does anybody know if the pink connector for temp and fuel gauges is 12V when you turn the key on? This would be checking the harness under dash with no gauges hook to it! Thanks if you can help! Jimi
jimi302z28s is offline
post #2 of 6 (permalink) Old Jun 30th, 06, 06:57 PM
Re: 69 console harness questions
Yes, it does.
The pink wire is the output of the "guages" fuse, it provides power to those 2 guages, plus the tach, ebrake light, & low fuel light.
post #3 of 6 (permalink) Old Jun 30th, 06, 07:39 PM Thread Starter
Thanks Jim, Iam not getting any voltage reading at the temp or fuel pin? So there has to be a break in the wire from the harness to the fuse box right? I do have voltage at the fusebox that runs the console gauges, Where would my problem be?? Thanks Again Jimi
post #4 of 6 (permalink) Old Jun 30th, 06, 08:02 PM
bad connection where the console harness plugs into the dash harness maybe?
Does your ebrake warning light work, it uses the same power source
post #5 of 6 (permalink) Old Jun 30th, 06, 08:23 PM Thread Starter
Thanks, I do not know if the ebrake warning works? Are you talking about the brake light on the left side of the dash?
post #6 of 6 (permalink) Old Jul 1st, 06, 04:35 AM
yes, that's the one.
Also the tach and low fuel light get power fron the same source.
easiest new guage console for 69 vegascamaro Interiors 5 May 10th, 06 12:28 AM
69 Camaro, Tagless, some questions. Ted Grevers Tag Team 5 Jan 8th, 06 06:57 AM
Installing console gauges and wiring. Questions... jumpmaster Electrical & Wiring 7 Aug 23rd, 05 05:36 PM
69 Console Wiring Questions 69-er Electrical & Wiring 4 Aug 14th, 05 08:51 PM
console harness question drptop70ss Camaro Tech 1 Mar 17th, 04 09:27 AM
