Relay with Timer Function - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 2nd, 06, 09:06 AM Thread Starter
Steven
I am looking for a relay/timer that will do a countdown function . The intent is to have power to a particular device for a limited time , like cars where the radio/windows will work for a couple of minutes after the key is turned off . If any of you have come across such relays, or, if you have any ideas on how to go about this, I look forward to your posts. Thanks in advance... Steven
sdtsdt is offline
post #2 of 6 (permalink) Old Jul 2nd, 06, 09:40 AM
Re: Relay with Timer Function
Go to google and type these words in the search box:
12vdc timing relay
69,700 hits on my first try.
onovakind67 is offline
post #3 of 6 (permalink) Old Jul 2nd, 06, 09:41 AM
Jeff
try this:
http://electronickits.com/kit/complete/elec/ck1611.pdf
i think its 20 bucks.
relay will handle 28Vdc @ 10 Amps. How much current do windows and radio draw? You could probably beef up the relay if its not enough.
you could piece this thing together too if you dont want to buy the kit.
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
jks67SS396 is offline
post #4 of 6 (permalink) Old Jul 2nd, 06, 01:34 PM Thread Starter
Steven
Yeah, onovakind67, I had done some searches ... I was trying to short cut the research process by seeing if someone had previously done this and had found a product that they were happy with ...
Thanks jks ... I read through the doc ... Here is another possibility that I found that may also work. I am posting in case someone else is interested
http://www.caraudio-caralarms.com/528T.html
If anyone had done this, please don't consider this thread closed ...
sdt
sdtsdt is offline
post #5 of 6 (permalink) Old Jul 2nd, 06, 03:39 PM
12vdc timing relay
What's google?
One useless post deserves another!
1969 RS/SS 396 Camaro [MPFI Supercharged 502 Under Construction]
2007 427 Z06 Corvette
1969 Pontiac 2+2 427/390
2003 CL600 BiTurbo Renntech Stage III (635hp - [email protected]) [Sold!]
2006 Range Rover Eaton Supercharged
davepl is offline
post #6 of 6 (permalink) Old Jul 2nd, 06, 06:20 PM
Originally Posted by davepl
What's google?
Welcome to the internet, young man, and if you can learn how to use it to your advantage you will be a lot smarter. Google is perhaps the largest and fastest search engine in operation today. A search engine is a program which acts as a card catalog for the Internet. Search engines attempt to index and locate desired information by searching for keywords in which a user specifies. The method for finding this information is usually done by maintaining indices of Web resources that can be queried for the keywords entered by the user. http://www.netsetgo.com/glossary.php
You can practice this for yourself. In your navigation toolbar, the one that now says https://www.camaros.net/forums/******, type the words www.google.com and go there. You'll come to the Google home page and you can type anything you want in the search box. You'll find this to be a very powerful tool when you're upgrading your knowledge base.
When you learn how to google, it's sort of like learning how to fish. You don't have to depend on somebody else catching your fish for you. I would rather teach a guy how to fish than have to keep fishing for him.
horn relay wiring questions phishhead Electrical & Wiring 3 Apr 19th, 06 09:29 AM
67 a/c relay wiring help rfine67 Electrical & Wiring 5 Jul 29th, 05 04:55 AM
(Another) Horn Relay Question Desert 68 Electrical & Wiring 3 Sep 2nd, 02 06:24 PM
Relay wiring 69CamaroSS Electrical & Wiring 7 Jul 8th, 01 06:19 AM
