tic toc tac - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 3rd, 06, 08:13 PM Thread Starter
Talking tic toc tac
i installed auto meter gauges in my console- do i need a console gauge conversion harness like the one in the ricks catalogue page 199 item 6805 to get my tac and clock to work????????????? thanks
hammerandnailhandyman is offline
post #2 of 10 (permalink) Old Jul 4th, 06, 04:59 AM
Re: tic toc tac
it depends... you can go at it a number of ways, the conversion harness is probably easiest tho the most expensive.
When I did mine, I modified the existing pcb and dash harness. The tach signal wire was a separate peice even from the factory. I used the old fuel guage wire to route 12v bat into the dash for the clock.
Most of the info is here for the searching.
post #3 of 10 (permalink) Old Jul 4th, 06, 05:42 AM Thread Starter
Re: tic toc tac
do you know where i can get a wireing diagram-i think they should include a diagram with the unit when purchased but they do not
post #4 of 10 (permalink) Old Jul 4th, 06, 05:45 AM Thread Starter
Talking Re: tic toc tac
do you know where i can get a wireing diagram?
post #5 of 10 (permalink) Old Jul 4th, 06, 05:45 AM
Re: tic toc tac
The wiring diagram is including with the guage conversion harness, along with instructions. I do have all the info here, but I'm off to the parade ina moment, then to a party, then leave for billings tomorrow crack of dawn. Make sure you're email is public, I'll try to send you what I have today.
Do you have the tach style pbc for the cluster?
post #6 of 10 (permalink) Old Jul 4th, 06, 06:55 AM Thread Starter
Re: tic toc tac
i am new at th is so i know enough to be dangerous. the tac is oer that replaced th gas gauge when i installed the console gauges. not sure what the pbc stile is????? the connector in back of dash gauges is original and has not been replaced. i did cut the tan lead to use for gas gauge in console. i did replace circuit board in back of gauges. my e-mail is [email protected]
post #7 of 10 (permalink) Old Jul 4th, 06, 08:58 AM Thread Starter
Re: tic toc tac
my email is [email protected]
post #8 of 10 (permalink) Old Jul 4th, 06, 09:01 AM Thread Starter
Re: tic toc tac
hello
post #9 of 10 (permalink) Old Jul 4th, 06, 09:02 AM
Re: tic toc tac
your best bet then is to get the console guage conversion harness. All the repro houses sell it and it comes with instructions. Assuming your autometer set includes a voltmeter rather than the stock type ammeter, and also assuming you've got an electric oil pressure guage, you'll need to make a change or 2, but it's no big deal.
post #10 of 10 (permalink) Old Jul 4th, 06, 12:55 PM Thread Starter
Re: tic toc tac
thanks for the help
tic toc tac hammerandnailhandyman Electrical & Wiring 20 Jul 9th, 06 12:14 PM
Tic Toc Tac Install Brentmc Electrical & Wiring 4 May 26th, 06 11:09 AM
Clock problems in Tic Toc Tac deamar Electrical & Wiring 4 Apr 13th, 06 09:44 PM
68 camaro tic toc tach tom weinel Camaro Tech 1 Apr 2nd, 06 07:15 AM
Will my Tic Toc Tac work with an HEI unit? JoshC Electrical & Wiring 4 Aug 30th, 05 03:06 PM
