Battery Fuse Amperage - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 5th, 06, 10:17 AM Thread Starter
HI All, adding an inline fuse at my battery (That has been relocated to the trunk). Just wondering about amperage. I have a 68 No Heater or AC/ Electric Fan and fuel pump/100 amp alternator. Other than lights no other major draws like a big stereo or anything.
Had 2 questions:
1) Is there a problem with adding a "large" fuse at the battery? (The rest of the car is fused correctly). My battery is in the trunk and I don't like having a 15 foot run of un-fused battery cable.
2) I have a 175 amp fuse and a 225 amp fuse?? Which one would you reccomend? Seems like the 175 would work but from what I understand the starter pulls alot of amperage on startup.
Chris
freebird is offline
post #2 of 5 (permalink) Old Jul 5th, 06, 11:01 AM
Re: Battery Fuse Amperage
starters can pull up to 500 amps on a bad day, so either of the fuses you have could blow without there even being a short
if you look at any car, the factory will never put a fuse in the line going to the starter
i installed a switch back one the battery so if something happens i hopefully can jump out and cut the power...
400bird is offline
post #3 of 5 (permalink) Old Jul 5th, 06, 02:06 PM
Also fuses create resistance although a low resistance at that. The trouble is that it only takes a few hundreths of an ohm to cause your starter not to crank.
dnult is offline
post #4 of 5 (permalink) Old Jul 5th, 06, 02:47 PM
What about installing a remote start solenoid, such as MAD's kit: http://www.madelectrical.com/catalog/st-1.shtml. Obviously you can do it yourself without the kit too. This way you only have power through the thick battery cable while cranking. The main power wire from the alternator should have a fusable link.
cr8zy68 is offline
post #5 of 5 (permalink) Old Jul 5th, 06, 07:40 PM
When I put fuses on the main battery feed to the starter I've used 300A ANL styles. I also use the ANL holder and leave one of the wires a tad long by the fuse holder so that if the fuse does blow from trying to crank it and you are out in the middle of nowhere you can take the one terminal off of the one stud and put it on the other stud to allow the engine to crank and then once home you can get a new fuse and put it back the way it was. On some of the race cars I've done I sometimes wire tie a spare to the power cable to where if it needs replacing another is handy and close by (no one has to go digging around for a spare).
Here's the parts I use:
http://community.webshots.com/photo/...49730488lzaqIa
The fuse holder accepts ring terminals on it and ideally solder those ends to the cabling you have run in your car and also any other connections onto the wiring. Also don't forget to have a good solid ground from the battery to the engine and from the battery to the body. You can have the biggest power wire feeding the starter but if the return path (ground) is insuffecient or improperly terminated and connected this can cause all sorts of problems.
SOA-Nova is online now
Electrical Basics, Part 2, Circuits JimM Electrical & Wiring 4 Sep 9th, 09 08:16 PM
Battery Fuse freebird Electrical & Wiring 2 Jun 30th, 06 08:29 AM
battery drains and can't find car alarm fuse wthotbeauty Electrical & Wiring 0 Mar 13th, 06 02:06 PM
BATTERY FUSED terminal on 67 fuse block gwarren Electrical & Wiring 2 Apr 25th, 03 05:00 AM
DieHard Security Battery Recall letter No 'E' in Camaro Electrical & Wiring 4 Nov 1st, 01 02:12 PM
