door jam switch ? - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 5th, 06, 06:19 PM Thread Starter
door jam switch ?
I purchased a set of switches from Ricks, and I cant close the door, there to long. Please enlighten me on whats going on, Ricks does not have shorter ones. Is it that there not available for a 67 coupe. If anyone knows where I can get them I would appreciate it.
Thanks Rich
67ragtp is offline
post #2 of 5 (permalink) Old Jul 5th, 06, 06:50 PM
Re: door jam switch ?
Most of the door jam switches of the plunger type such as our cars use are self adjusting. They are too long when new, but when installed and the door is closed for the first time, the sleeve around the plunger slides back into the switch body to self adjust for the individual door gap.
red67camaro is offline
post #3 of 5 (permalink) Old Jul 5th, 06, 07:17 PM
Call me Funk
Send a message via AIM to CFunK
I went through the same thing recently. I too was spooked at the length of the switches. Just install it and give the door a good shove to close it. The switches will seat themselves and adjust to the correct length.
-Funk
CFunK is offline
post #4 of 5 (permalink) Old Jul 5th, 06, 09:02 PM
You do have it screwed all the way in, right?
cr8zy68 is offline
post #5 of 5 (permalink) Old Jul 5th, 06, 10:23 PM
Correct.....and use a little WD-40 around the sleeves.
Camaro buds until the end!!!
Camaro Dave is offline
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 10:59 PM
68 vacuum headlights Opening but not closing AAAAGGGG!!! ray moore Electrical & Wiring 11 Jul 7th, 05 04:01 PM
Wiper switch grounding, heads up TC Codi Electrical & Wiring 0 Jul 5th, 05 09:29 AM
Wiper Switch Question mjm7496 Electrical & Wiring 6 Apr 5th, 05 10:41 AM
67 rs headlights 19673L4P Electrical & Wiring 6 Jun 23rd, 04 01:55 PM
