ground straps - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 6th, 06, 01:11 PM Thread Starter
chuck
ground straps
Does anyone know how many ground straps and the locations of them for a 69 camaro with a V8. I have been told all you need is 3 but I also have been told there were 5 ground straps. Thanks!
chucks69ss is offline
post #2 of 3 (permalink) Old Jul 6th, 06, 02:57 PM
parkbrau's Avatar
Re: ground straps
I am changing mine due to a new engine being dropped in. Anyway, there are 3. 1 each on both valve covers, connected to the firewall, and one on the subframe for grounding.
Get yourself an assembly manual. It shows where, they are supposed to go. Best 19.95 spent
john
parkbrau is offline
post #3 of 3 (permalink) Old Jul 11th, 06, 01:11 AM
Re: ground straps
There is actually 4 on V8s in the RPO U63/U69 AM or AM/FM Radio option.
1 on each valve cover (2),
1 connecting the subframe to the body near the body mount on the right side of the vehicle, and..
1 on the front right outer subframe rail, adjacent to the front (smaller) crossmember, attaching the subframe to the inner fender. This is the only ground strap that requires measuring the hole locations before drilling. All other holes are existing, or have dimples to indicate their location.
See AIM pgs440-1, RPO-U63/A6-7.
BlackoutSteve is offline
ground straps on 69 69Rfine Restoration Corner 19 May 6th, 06 06:28 PM
Ground straps noels69 Electrical & Wiring 3 Dec 2nd, 04 04:27 PM
ground straps pace11 Electrical & Wiring 3 Dec 11th, 02 03:29 AM
'68 Ground straps kel Electrical & Wiring 2 Jun 15th, 01 02:11 PM
Ground straps POP D TOP Electrical & Wiring 3 Aug 17th, 00 03:17 AM
