right directional - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 7th, 06, 06:25 AM Thread Starter
right directional
I just finished re-wiring the entire car with factory fit harnesses. I also installed a new tach. Everything works perfect except for one thing: when i pull the headlamp switch the right directional stays lit. If I put the key in the ignition the blinker works fine. When I take out the key and move the turn signal the light goes out. However, with the key in, moving the turn signal causes the blinker to operate. Anyone have any ideas?
scottl2 is offline
post #2 of 5 (permalink) Old Jul 7th, 06, 07:15 AM
Re: right directional
Check the ground at the right side bulb sockets. Without a good ground the voltage passes through both filaments and back to the dash indicator.
go2fast is offline
post #3 of 5 (permalink) Old Jul 7th, 06, 10:22 AM Thread Starter
ok thats connected - still lit
scottl2 is offline
post #4 of 5 (permalink) Old Jul 7th, 06, 12:49 PM
You checked front and rear? How did you determine the grounds were good? Do you have a meter? Also try pulling the bulbs one at a time and see if one of them makes the dash light go out. Sometimes the filaments short to each other in the bulb (or that's the one with the bad ground).
go2fast is offline
post #5 of 5 (permalink) Old Jul 7th, 06, 05:14 PM Thread Starter
I should clarify, this is the directional on the dash. The blinker light for the right blinker. I
scottl2 is offline
Replace directional indicator bulb- '69 Camaro Billy Electrical & Wiring 2 Mar 2nd, 06 03:14 AM
Directional Tires DTL504 Wheels & Tires 2 Feb 27th, 03 09:01 AM
Need directional advice garfield Electrical & Wiring 5 Nov 30th, 02 01:16 AM
Vigilite Directional signals on fenders HawaiianCamaro Electrical & Wiring 6 Feb 24th, 01 06:28 AM
