2 Condensers ??? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 7th, 06, 12:47 PM Thread Starter
2 Condensers ???
I just checked into my coil and dist. to change the points out to the Pertronix and I found that the guy before me put an external condenser on the outside of the coil. He taped a condenser to the coil and has it attached to the positive side of the coil (same side as the resistor wire). I took the cap off of the dist and there is a condenser attached on the dist along with the points.
My question, why would someone do this?
Is there a way to check if the condenser in the dist is good and the one on the coil removed?
I took off the connection on the condenser on the coil and the car ran fine.
Any ideas or help would be appreciated. Anything! I am stumped on this one.
BTW, the car is a stock 302 - Z.
klingrr is offline
post #2 of 4 (permalink) Old Jul 7th, 06, 12:51 PM
parkbrau's Avatar
Re: 2 Condensers ???
I would remove both of them. You dont use any condenser with the Pertronix.
Maybe it was for the radio? Does that make any sense?
parkbrau is online now
post #3 of 4 (permalink) Old Jul 7th, 06, 01:02 PM Thread Starter
I did not do the Pertronix yet just because I do not know why the second one is there. Is there a way to tell if the second one is for the radio? Any other ideas???
klingrr is offline
post #4 of 4 (permalink) Old Jul 7th, 06, 03:39 PM
GM did mount condensors (capacitors) on the coil bracket and sometimes on the alternator and or regulator and even the fuseblock to suppress radio noise.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
