how to replace 67 ignition switch ? - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 8th, 06, 04:03 PM Thread Starter
I have the new switch,,,and was able to get the chrome bezel lose on the dash side,,,,but it only un-screws so far. Is the a trick to getting the front chrome rings off?
Herb396 is offline
post #2 of 6 (permalink) Old Jul 8th, 06, 04:23 PM
Christropher
Re: how to replace 67 ignition switch ?
Remove the inner lock cylinder with the key and a paper clip.
Christropher
...in pieces still.
clwilcox33 is offline
post #3 of 6 (permalink) Old Jul 8th, 06, 04:28 PM
Farm Boy's Avatar
You need to remove the lock cylinder first. Insert the key and turn it counterclockwise to the ACC position. Insert a small wire (paper clip) into the small hole in the cylinder to depress a button inside the switch. With the button depressed turn the key and cylinder counterclockwise beyond the ACC position. The cylinder will now come out and you will be able to remove the bezel and the switch.
Farm Boy is offline
post #4 of 6 (permalink) Old Jul 8th, 06, 04:30 PM
Christropher
Good instructions Steve! Sorry, I was being a little lazy and just "hoping" he would figure it out given the step to take
Christropher
...in pieces still.
post #5 of 6 (permalink) Old Jul 8th, 06, 06:06 PM Thread Starter
Thumbs up Re: how to replace 67 ignition switch ?
Great instructions,,,got it. New switch is in !
You guys are great !
thanks
Herb396 is offline
post #6 of 6 (permalink) Old Sep 2nd, 19, 02:04 PM
Probationer
Add another success to the archives!
Done and Done.
MUYA!
Marshall124 is offline
ignition switch edward1970 Electrical & Wiring 0 Dec 19th, 05 06:31 PM
Ignition switch - help on identifying kfinsrud Troubleshooting 5 May 12th, 05 10:49 AM
1995 Camaro Ignition Switch mdlhorse Electrical & Wiring 0 May 4th, 05 07:03 PM
ignition switch sebastieng Electrical & Wiring 0 Apr 2nd, 05 04:05 PM
How do I put the bezel on ignition switch? rmadsen55 Camaro Tech 2 Jun 24th, 04 07:39 PM
