Directional Signals - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 10th, 06, 05:13 PM Thread Starter
Directional Signals
When I flip the turn signal lever to make a right my front and rear lights work but the light in the dash does not. Could this be the flasher that's causing the problem.
Schoon
SCHOON is offline
post #2 of 4 (permalink) Old Jul 11th, 06, 12:55 PM
Re: Directional Signals
Sounds more like the indicator bulb in the dash is burned out or the socket is loose. These can be a real pain to reach.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Jul 11th, 06, 09:30 PM
If the front and rear turn signal lights are working the flasher is okay. As 12run stated above, it's most likely the indicator bulb.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 4 (permalink) Old Jul 12th, 06, 03:53 PM Thread Starter
I went under the dash tonight to see about removing the indicator light. Man is it tight in there. There is one plastic gang of of connections that are for idiot lights that are not wired up, only the turn signal is wired up. I am thinking the bulb must be very small and in front of this plastic part. There is 2 metal clamps one on each side of the plastic part. Any ideas on how to remove them so I can get to the bulb.
Schoon
SCHOON is offline
4 way flashers work but turn signals don't HELP PERKS67-396 Electrical & Wiring 11 Jun 24th, 15 08:37 PM
Taillights, backup, and rear turning signals don't work mike3026 Electrical & Wiring 2 Sep 30th, 05 06:28 PM
Alien signals from 1000 light years away Brian Lewis Bench Racing 4 Sep 3rd, 04 06:14 AM
Can't figure out turn signals!! scalise Electrical & Wiring 1 Feb 10th, 02 06:56 AM
Vigilite Directional signals on fenders HawaiianCamaro Electrical & Wiring 6 Feb 24th, 01 06:28 AM
