'67 OER temp gauge not showing correct temp - Team Camaro Tech
post #1 of 18 (permalink) Old Jul 11th, 06, 04:42 PM Thread Starter
Paul
I don't know if anyone else has had this issue but thought it would be worth a shot.
I'm trying to get the console gauges in my '67 Camaro to work again. During my subframe off restoration, I replaced all the harnesses (engine, under dash, console, etc...) I then replace the temp gauge w/an OER repro gauge and I installed a GM temp sensor in the block.
The gauge shows the temp @ cold when the car first starts but it goes all the way to hot as the car warms up. I hit the rad hose and thermostat housing w/the temp sensor in my multimeter and the car isn't overheating. Running about 200-205. The guage actually reaches the hot mark around 150 degrees.
I read that you don't need the factory resistor for the OER guages b/c it is built into the guage. I'm not running a the factory resistor. I also swapped out the temp sensor w/another one and got the same results.
I'm getting closer to having this thing work. I'm about to order a new sending unit from http://www.lectriclimited.com . Before I throw another $20 at the problem, I figured I'd ask the question.
The guy I bought the car from had the console gauges in pieces. I have two resistors but can't tell which one goes to the temp vs the gas gauge so if I have to use the reisistor, I'd appreciate it if someone can help me figure out which one goes to which gauge.
Sorry for the long post.
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
post #2 of 18 (permalink) Old Jul 11th, 06, 05:05 PM
madmax87's Avatar
Re: '67 OER temp guage not showing correct temp
I'm not sure on a 67 but on a 69 you are correct about not using the external resistor on the OER gauges. Where is you sending unit located? (on the head)? Are you sure you have the correct sending unit on the car. I've read about air pockets getting trapped in the cooling systems giving you weird readings like your seeing.
madmax87 is offline
post #3 of 18 (permalink) Old Jul 11th, 06, 05:12 PM Thread Starter
Paul
My sending unit screws into the side of the block on the drivers side by the exhaust manifold.
I hope I have the right sender b/c I ordered two of them @ different times over the past couple of years. This is one of the reasons I'm thinking about using this vendor some folks were raving about on the board and on chevelles.net
Bought it
Rebuilt it
Almost done
oakster is offline
post #4 of 18 (permalink) Old Jul 11th, 06, 06:54 PM
My Understanding is that the plug on the block is for a warning light sensor only. The head temps are higher then coolant elsewhere. The sending unit should be on the intake manifold near the thermostat.
Pete '68 427
68427 is offline
post #5 of 18 (permalink) Old Jul 11th, 06, 07:00 PM
Sending unit on a small block goes in the drivers side head between the number 1 and 3 spark plugs. Both the temperature sender or the temperature switch go in the same place. At least on a 69, don't know if the 67's have the hole tapped for a sensor or not.
Gas gauge resistor is 46 ohms, temperature gauge resistor is 86 ohms.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 18 (permalink) Old Jul 12th, 06, 04:46 AM
Oakster
The gauge on my '68 does the EXACT same thing. I have an OER gauge, Facotry Fit wiring harness and the sender you are talking about from Lectric Limited. I've checked the temp with one of those "infared" thermometers and I'm right at about 200 max no matter where I take the temp reading from. Since I have new wiring and the correct calabrated sender, my guess is I need a new guage. I bought one, just haven't had a chance to put it in yet.
I'd try the new sender but if that doesn't work - it's got to be the guage.
Dan
'68 Camaro Convertible
dschribs is offline
post #7 of 18 (permalink) Old Jul 12th, 06, 05:09 AM
67s are in the intake and you may have to get an old sinding unit for it to read correctley. Most after martket seem to read too high at least thats what it seems like to me. Even the newer ones from GM are that way. I take them out of old intakes and they seem to work fine
green z is offline
post #8 of 18 (permalink) Old Jul 12th, 06, 09:26 AM
Originally Posted by oakster
The guage shows the temp @ cold when the car first starts but it goes all the way to hot as the car warms up. I hit the rad hose and thermostat housing w/the temp sensor in my multimeter and the car isn't overheating. Running about 200-205. The guage actually reaches the hot mark around 150 degrees.
You will probably need to add a resister to make the gauge read correctly. The gauge is out of range for the sender being used. You can always ask OER
http://www.oerparts.com/ their email address is at bottom of page.
http://www.chevelles.com/forums/showthread.php?t=55524
The guy I bought the car from had the console guages in pieces. I have two resistors but can't tell which one goes to the temp vs the gas guage so if I have to use the reisistor, I'd appreciate it if someone can help me figure out which one goes to which guage.
I might be able to find out, measure how many ohms each resister is and post back.
Greg U
undee72Z is offline
post #9 of 18 (permalink) Old Jul 12th, 06, 09:37 AM
foreverlookin's Avatar
MarkC, I am kind of confused (which comes easy to me!) I thought that the fuel sending unit operated 0 - 120 ohms? I am still trying to figure out my temp sending range.
foreverlookin is offline
post #10 of 18 (permalink) Old Jul 12th, 06, 09:47 AM Thread Starter
Paul
I'll measure the resistors when I get home tonight. I also sent OER an e-mail regarding the issue I'm having with their gauge. I'll let you know what they have to say.
I'm also probably going to try relocating my sending unit to one of the plugs in the intake to see if that helps.
I'm actually happy that I finally got the gauge to do something. Been reading up on the site b/c the gas gauge is next.
Bought it
Rebuilt it
Almost done
oakster is offline
post #11 of 18 (permalink) Old Jul 12th, 06, 10:52 AM
Oakster
Try a different sender. It's probably the easiest way to go in terms of labor at this point. OER gaugues don't need reistors - they have them built in. If the gauge isn't working properly with the new sender, I'd say the gauge is no good. The quality of most repo stuff has alot to be desired. No reason to think the gauges would be any different.
Let me know what's OER's response is. I'd be ineterested to know what they say.
Dan
dschribs is offline
post #12 of 18 (permalink) Old Jul 12th, 06, 12:20 PM Thread Starter
Paul
I'm going to try a couple of things based on this e-mail
1 - Moving sending unit to intake (I have 2 GM sending units)
2 - Adding 86 ohm resistor to the gauge
3 - Using new sender from lectriclimited.com (ordered today)
I'm too close to giving up on this now. Plus it freaks me out ot be cruising around during the summer w/no temp gauge. I can deal with no gas gauge for now but it is next on my list.
Thanks for everyone's input and ideas - I'll let you know how I make out and what OER has to say.
Paul
Bought it
Rebuilt it
Almost done
oakster is offline
post #13 of 18 (permalink) Old Jul 12th, 06, 02:12 PM
The resistors I qouted above, are the external resistors mounted on the back of the gauge in either the console or in the dash not the resistance of either the sender in the block or in the fuel tank. They provide the counter emf to drive the needle downscale and also affect the scale of the guage. If they weren't there then when the car heated up and the temperature gauge went up scale, it would never go back down to cold the next time you started the car. Same with the fuel guage, except it works the otherway around (drives the needle towards full).
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #14 of 18 (permalink) Old Jul 12th, 06, 06:12 PM Thread Starter
Paul
I tested the resistor and it was right @86 ohms. When I put it on the gauge, the guage now goes to below C but doesn't seem to come off of cold.
It is pouring up here in Mass tonight so I can't take the car out for a good ride to see it it moves when it really heats up. Looks like I'll have to play around some more and start getting readings from the sending unit too.
Bought it
Rebuilt it
Almost done
oakster is offline
post #15 of 18 (permalink) Old Jul 13th, 06, 04:41 AM
Re: '67 OER temp gauge not showing correct temp
Oakster
Any response from OER?
Also, I've heard of some guys just pulling the needle off the guage, letting the car heat up to operating temp and putting the needle back on the gauge at about the half way point on the gauge. The gauge really just gives you an idea as to if your car is at "normal" temp anyway. So if you know where the needle is on the guage at your cars normal operating temp day and day out, you can tell if things are getting too hot if the needle starts to move past that point.
Porbably not the best solution but it might do the trick and save you lots of hassles in the long run.
Dan
dschribs is offline
Temp guage again , sorry click Electrical & Wiring 19 Jun 25th, 05 03:35 PM
Temp guage quit working in my69 click Electrical & Wiring 3 Jun 15th, 05 04:13 AM
AFR heads & orig guage - which temp send unit?? SooperDave Engine 1 Apr 12th, 05 05:31 PM
Temp guage gone bad ? 69jbjohn Electrical & Wiring 3 May 7th, 04 04:44 PM
Factory Temp Guage reading Robert Stacho Tech 2001 7 Oct 7th, 01 03:17 AM
