1969 left front signal - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 13th, 06, 06:04 PM Thread Starter
My front left signal is not flashing, but the fog light works, I replaced the flasher and nothing. It is also much slower then the right one. Can the cancelling cam go bad?
6070kid is offline
post #2 of 4 (permalink) Old Jul 13th, 06, 06:13 PM
Re: 1969 left front signal
the cancelling cam has nothing to do with blinking, only cancelling.
The flasher is used in the same way for both sides, so it';s not the problem.
Most likely you have a bulb or 2 out somewhere, and the flasher is not getting loaded enough to flash. Could be a bad ground.
What car?
post #3 of 4 (permalink) Old Jul 13th, 06, 06:14 PM Thread Starter
1969 rs/ss camaro cnvt.
6070kid is offline
post #4 of 4 (permalink) Old Jul 13th, 06, 07:27 PM
My guess is that you have a bulb out. Check all of them and replace the bad ones. Or it might be a bad connection or ground. That will take further checking with a test light etc.
TTFN
Mat
SSCARGO
Mat Klemp is offline
front turn signal bulb replacement in a 2001 camaro tantu Troubleshooting 0 Dec 27th, 05 09:46 AM
Driver side brake and front light brighter than left? FastFred Electrical & Wiring 0 Nov 7th, 05 05:56 AM
67 rs front left turn signal won't work 67L35 Electrical & Wiring 3 Jun 3rd, 04 12:53 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
