Temp Idiot Light Test???? - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 13th, 06, 08:11 PM Thread Starter
Is there any kind of ez test I can do to see if my temp idiot light is working? Is it supposed to come on for a second when I first turn the key to start my car? Do you think I could hold a cigarette light under the connection that goes to the manifold? Apparently boiling water wouldn't be hot enough to trigger the idiot light on my dash. Is there a way to test it with a test light? Thanks
327!275hp!Convt! is offline
post #2 of 2 (permalink) Old Jul 13th, 06, 08:19 PM
Re: Temp Idiot Light Test????
The light will light to test it when the car is CRANKING, and go out when you release the key to run. This happens by a bypass wire, green to the ignition switch, which is grounded in start. It tests the lamp, but not the wiring to the engine or the sending unit.
To test the rest of the wiring, it is perfectly safe to remove the wire to the sending unit, and short it to any available ground, the alternator case is a good spot. If the key is on, the light should light.
acceptable operating temp for ss396? fivestarstudios396 Heating & Cooling 6 Feb 21st, 06 11:12 AM
Hazard and Turn Signal Light Issue 68camrs Electrical & Wiring 2 Jan 5th, 06 12:47 PM
Idiot light mask for 67 with gauges low fuel JeffLit Electrical & Wiring 1 Dec 4th, 05 06:04 PM
91 Camaro temp sensors concerns.... Cam Sweet Troubleshooting 0 Aug 3rd, 03 12:40 PM
Temp Light... ohayden Electrical & Wiring 8 Apr 27th, 01 03:27 PM
