1987 5.0L TPI Z28 Engine problem - Team Camaro Tech
post #1 of 1 (permalink) Old Jul 14th, 06, 12:37 AM Thread Starter
Angry 1987 5.0L TPI Z28 Engine problem
I posted in here because I beleive it to be an electrical problem. Here are my current specs:
1987 Camaro 5.0L TPI engine rebuilt and placed in a 1991 Camaro
Junkyard engine, distributor was NOT rebuilt
Electronic advance on distributor
New spark plug wires, MSD Coil, spark plugs, and ECM.
Old wiring harness with some custom wiring
The symptoms are:
-Engine used to be able to start, but never could be timed correctly, it would sputter, and jump, and backfire, no matter where I adjusted the distributor to
-Sometimes when engine was started it idled at 2000 RPMS! happened once every 20 times I think
-average idle was 250-500RPMs
-During timing it sputtered, slowly got worse, and stalled out, tried restarting the engine and it would not spark
Could I have overloaded the ignition module with the MSD blaster coil? The coil has a 42,000 volt rating. Could the old distributor need a few new parts, like rotor and cap? maybe a rebuild with MSD or Accel parts? Could it be a mechanical problem within the engine?
EDIT: Here is a link to a video I made when I was first running the engine. It was running open headers because the exhaust is not 100% finished. This should help you guys know how the engine was running. in this it was before it was timed enough to idle, it could not idle so I had to rev it once in a while
http://musclecartuners.net/videos/imbackinblack.wmv
Racing_Master is offline
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 12:44 PM
New Stroker Engine...But...A Problem (Long) bigdawginva Performance 57 Mar 11th, 05 02:33 PM
Sleuthing a new engine problem Tokyo Torquer Performance 16 Jan 3rd, 05 09:01 AM
EBAY or Build Balboni Performance 16 Jun 3rd, 03 10:16 AM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 06:41 AM
