RS diode harness - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 17th, 06, 02:33 PM Thread Starter
Tim
Send a message via AIM to sixtsevnssrs
Angry RS diode harness
On my 67,
I have my new motors, relays and harness all wired up, I have my diode harness connected to the light harness coming back through the firewall but can anyone tell me where it goes from there? Not one diagram I have shows me anything.
One blue wire, with two connectors (one bare and one OEM type plastic connector)
One Brown wire, with two connectors (one bare and one OEM type plastic connector)
Tim
sixtsevnssrs is offline
post #2 of 3 (permalink) Old Jul 18th, 06, 01:11 AM Thread Starter
Tim
Re: RS diode harness
OK, I think I figured it out. Diode harness comes back through the firewall. Lt blue wire is pulled from the headlight switch, insert unshielded connector in the slot you just removed the lt blue wire from, plug the wire you removed from the switch into the shielded connector provided on the harness.
Brown wire is removed from the ignition switch, unshielded wire from doide harness is inserted into the switch where you just pulled he brown wire out of and then slide the wire you pulled from the switch into the shielded connector on the diode harness.
wires can be easily removed with a small screw driver inserted to force the locking tab down and allows the connector to be pulled out.
Tim
post #3 of 3 (permalink) Old Jul 18th, 06, 11:16 PM Thread Starter
Tim
Thumbs up Re: RS diode harness
Everything works great!!!
Tim
New wiring harnesses - help please! Eric Kammerer Electrical & Wiring 3 Jun 22nd, 05 09:48 AM
67-68 underdash harness tim Electrical & Wiring 5 Apr 14th, 05 12:25 PM
Advice on wiring harness. ck 2 Electrical & Wiring 11 Dec 31st, 04 07:37 PM
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 06:36 PM
rs under dash diode harness mike shields Electrical & Wiring 0 Jul 7th, 03 03:37 PM
