69 console temp gauge not working - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 17th, 06, 11:21 PM Thread Starter
Unhappy 69 console temp gauge not working
i have hooked up my console gauges and they all work but the temp gauge. so i bought a new gauge and it does not work either. when i bought the original gauges they were already hooked up in there cluster and were ready to bolt to console. i have a new sending unit on the block, new console harness for the gauges and now 2 new temp gauges. all the lights work, safty neutral works, fuel gauge, oil, amp and low fuel lights work so i think i have it all hooked up correct but temp does not work. HELp!!!!
garyj is offline
post #2 of 4 (permalink) Old Jul 17th, 06, 11:30 PM
madmax87's Avatar
Re: 69 console temp gauge not working
What type of sending unit did you get. It needs to be for the console gauge package. You don't have any resistor across the terminals do you. Are your gauges original or OER.
madmax87 is offline
post #3 of 4 (permalink) Old Jul 17th, 06, 11:42 PM
Brad
Whats your temp. gauge doing when you turn the key on? If you ground you sending unit wire the gauge should peg hot. Let us know. Brad
Most recent 01/01/10
spideynut is offline
post #4 of 4 (permalink) Old Jul 22nd, 06, 12:32 AM Thread Starter
Unhappy Re: 69 console temp gauge not working
hi, when the key is turned on nothing happens. put ohmn meter in the gauge wiring clips that hook to gauge and i get readings. how can i check to see if gauge works? although i have 2 new gauges? thanks gary
garyj is offline
'68 console temp gauge rear diagram fastred57 Electrical & Wiring 0 Oct 10th, 05 11:53 AM
What parts are needed to convert 69 AT console to 68 4 speed Winch Interiors 0 Sep 19th, 05 06:32 AM
console oil press gauge leaks BAMiller Interiors 13 Aug 18th, 05 06:00 PM
Temp gauge pins to cold in my 69 Dougs 69 cam Electrical & Wiring 6 Sep 12th, 04 03:18 AM
'69 Z28 Console Temp Gauge Donnie Legate Electrical & Wiring 3 Apr 12th, 01 04:30 PM
