67 sail panel lens replacement - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 19th, 06, 08:50 AM Thread Starter
Jeff
guys,
How do i get the sail panel lens off to replace a light bulb and the lens?
thanks
jeff
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
jks67SS396 is offline
post #2 of 4 (permalink) Old Jul 19th, 06, 09:04 AM
Vintage 68's Avatar
Thumbs up Re: 67 sail panel lens replacement
Jeff:
You can use a small-thin bladed screwdriver inserted between the bezel and the lens on either side to release the retainer lug. Then pry the lens off to acess the bulb.
The older lenses become very brittle and will discolor and break easily when you try to remove them. Since you have a new lens already, be ready to install it...
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 4 (permalink) Old Jul 19th, 06, 09:44 AM Thread Starter
Jeff
thanks John. ill give it a shot
1967 SS 396, M20.
post #4 of 4 (permalink) Old Jul 19th, 06, 01:30 PM
Joe
GMJoe's Avatar
i warmed mine up with a blow drier then used a small screw driver to pop em out, i wasnt taking any chances
'67' RS
GMJoe is offline
67 deluxe door panel emblem robbaker Interiors 0 Apr 13th, 06 03:22 PM
67 Quarters and Tail Panel Indy Z11 Body Shop 2 Mar 12th, 06 10:22 PM
Sleeving the quarter panel to the sail panel??? Liveinaz Body Shop 3 Jul 1st, 05 08:04 PM
Sail Panel Ridge by drip rail, any pictures?? Buildinga55 Body Shop 0 Jul 1st, 05 07:46 PM
Sail panel Install question. ray moore Interiors 13 Mar 12th, 05 01:44 PM
