why dont my horn work - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 19th, 06, 06:09 PM Thread Starter
Question why dont my horn work
my horn dont work it work good one day and then it stop
why????
please help thanks 1969 camaro ss rs 4 speed
camaro9 is offline
post #2 of 7 (permalink) Old Jul 19th, 06, 06:25 PM
Re: why dont my horn work
can you hear the horn relay click when you push the horn button?
It's on the drivers side of the radiator support and clicks pretty loud.
I'm gonna have this moved to electrical, this forum is for membership questions.
post #3 of 7 (permalink) Old Jul 19th, 06, 08:28 PM
This paper may help diagnose your problem.
http://jimshea.corvettefaq.com/wp-co...ACar13JN06.doc
Hope this helps,
JIML82
JIML82 is offline
post #4 of 7 (permalink) Old Jul 20th, 06, 02:18 PM Thread Starter
hi thanks for answering my question on why my horn dont work. when i push the horn i hear nothing i have new horns and horn relaynothing happen when i push the horn. question is there a wire that goes up the steering colums from the horn relay another question what make contact under the steering wheel for the horn to work does the cancelling cam have any thing to do with the horn working as far as contact the what ever? ihave the steering wheel that has the two contacts on each side
thanks again for your help
camaro9 is offline
post #5 of 7 (permalink) Old Jul 20th, 06, 04:22 PM
here's the horn relay wiring: https://www.camaros.net/techref/elect...horn_relay.htm
The black wire goes thru the harness, up the steering column, and ends up at the lil spring loaded "button" under the cancelling cam. The brass ring on the underside of the cancelling cam picks up the signal and brings it into the steering wheel to the horn buttons. When you press the button, it grounds the black wire and blows the horn.
post #6 of 7 (permalink) Old Jul 20th, 06, 04:55 PM
Z28 Mark's Avatar
Check the fuse….
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Camaros Limited~Nor Cal
Z28 Mark is offline
post #7 of 7 (permalink) Old Jul 20th, 06, 05:26 PM
the horn is not fused on a 67-69 Camaro.
Confessions of a body shop owner. MARTINSR Body Shop 39 Dec 6th, 12 01:51 PM
68 horn relay help needed shoe Electrical & Wiring 3 Mar 18th, 06 12:29 PM
Body shop referral in CT ponjohn Body Shop 5 Oct 19th, 03 06:24 AM
Horn Dilema on 68 MTidwell Electrical & Wiring 1 Dec 28th, 02 12:29 AM
horn relay? 68CMRO Electrical & Wiring 1 Sep 15th, 01 09:40 PM
