radio cuts out and power windows won't work - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 21st, 06, 08:33 AM Thread Starter
My 97 Camaro Convertible will have the radio intermittently cut off and power windows won't work when this happens. I had a new radio put in, but the old one did the same.What's strange is sometimes hitting the power lock button will bring it back on. Some times depressing the brakes will make it go off and releasing the brakes will make it come on. It doesn't matter if I'm driving on a bumpy road or not and tempurature doesn't seem to be a factor, it's just intermittent. Any ideas?
erinrain69 is offline
post #2 of 5 (permalink) Old Jul 21st, 06, 10:15 AM
Harry
dawg's Avatar
Re: radio cuts out and power windows won't work
sounds like a short somewhere.
434 stroker
US Navy retired
dawg is offline
post #3 of 5 (permalink) Old Jul 21st, 06, 10:18 AM
Most likely a loose connection somewhere. Are the power windows (switched circuit for relay) and the radio on the same circuit?
Greg U
undee72Z is offline
post #4 of 5 (permalink) Old Jul 21st, 06, 12:55 PM
Try changing the fuse for the radio and inspecting the contacts where the fuse plugs in. If the fuse is flaky or the contacts aren't tight strange things can happen.
Cheers, NVR DUN
NVR_DUN is offline
post #5 of 5 (permalink) Old Jul 27th, 06, 07:02 AM Thread Starter
Thanks for all the input. I replaced the fuse and replaced the power window switch. It all seems to be working. Hopefully it will stay that way!
