1981 z28 wiring harness - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 21st, 06, 10:46 PM Thread Starter
Lightbulb 1981 z28 wiring harness
I recently bought a 1981 z28 and the wiring harness had caught on fire. I was wondering what years i could use the wiring harness out of or does it have too be the same year because this was the first year for the computer? Thank You Kevin
8182z28 is offline
post #2 of 5 (permalink) Old Jul 24th, 06, 07:28 PM Thread Starter
Re: 1981 z28 wiring harness
I cant believe there isnt somebody out there that has a answer too my ? about the wiring harness.
8182z28 is offline
post #3 of 5 (permalink) Old Jul 25th, 06, 01:41 AM
Are you still using the computer? How bad is the harness burnt? (unless the whole car is burnt up, they can usually be repaired) Which harness are we talking about (engine, dash, forward lamp, rear) 79-81's are pretty close. Why not get a new harness? You can always try a auto recycler, they might be able to find a car some where with what you need. As for getting responses, when asking about anything electrical, always give as much info as possible. (clear pics are worth a 1000 words) I seen your post earlier. I usually only respond to posts that I can give a correct answer to (or at least try to). Even if you answered my questions, I still wouldn't really have answer to your original question. Just being honest. I can tell you this, the most common cause of electrical fires is bypassing the safety devices (fuses and fusible links) Fusible links protect the wiring before the fuses. Be sure that they are all in place after the car is repaired.
Greg U
undee72Z is offline
post #4 of 5 (permalink) Old Jul 25th, 06, 10:43 PM Thread Starter
The wiring harness was on fire from the firewall out too under the hood. So i imagine it would be the engine harness. I really dont know That is what iam trying too find out. Thanks for any help.
8182z28 is offline
post #5 of 5 (permalink) Old Jul 26th, 06, 06:36 AM
Could be either the engine or foward lamp harness. If you have any other questions, post back.
Greg U
undee72Z is offline
Wiring Harness Help! tim68rsss Electrical & Wiring 2 Nov 28th, 05 05:08 AM
68 Z28 Engine Wiring Harness 68 rs z28 Electrical & Wiring 4 Nov 13th, 05 11:29 AM
New wiring harnesses - help please! Eric Kammerer Electrical & Wiring 3 Jun 22nd, 05 09:48 AM
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 06:36 PM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
