Need help on wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 24th, 06, 06:45 PM Thread Starter
ENP
Need help on wiring
I am new to the electrical game. I have a 69 camaro. I replaced every wire with new "Factory Fit" wire harnesses. The motor in my car is a GM 502. I have a electric fuel pump and dual fans for my radiator. The electric fuel pump and radiator fan wire goes to the ignition. My new fuse block shows a plug in that is labeled "IGN". I assume this is ignition. How do I wire both the fuel pump and fan wire to this "IGN". I really hope this made sense. I had a long day.
thanks
ENP is offline
post #2 of 4 (permalink) Old Jul 25th, 06, 02:10 AM
Re: Need help on wiring
thanks
The IGN terminal at the fuse box is for adding low power items. If you wired a fan to it directly, it would probably blow the fuse everytime you turned it on. Use a relay for these items. A relay is nothing more than a remote controlled switch. Relays use a small amount of power to turn on ( or off) a large amount of power, see pic and link
http://www.bcae1.com/relays.htm#demo
You can get relay kits that include the relay and all the wiring, Summit and Jegs sell them. Get power from the horn relay (espeically if you have a factory amp gauge and want it to work correctly) and make sure the alternator can handle the extra current demand. Fan wiring will depend on how you want to control it, automatically from a temp sender, manually with a toggle switch, or a combination of the two.
Greg U
undee72Z is offline
post #3 of 4 (permalink) Old Jul 25th, 06, 03:30 AM Thread Starter
ENP
My dual fans have a relay for each fan. Each relay has 4 wires. 1 wire goes to the battery positive(this has a 30amp fuse), 1 wire goes to the temp sending unit, 1 wire goes to the ignition and the last wire goes to the fan.
Can I splice the ignition wire of the fan directly to the ignition wire of the fuel pump. Once this is accomplished can I plug both the fuel pump and ignition wire of the fans directly to the "IGN" on the fuse block.
ENP is offline
post #4 of 4 (permalink) Old Jul 25th, 06, 12:30 PM
Are you going to use a relay for the fuel pump also? The switched side of a relay pulls very little power, something around 1/8 of a amp. You could wire the switched side of 20 relays to the IGN terminal at fusebox and not have a problem.
Greg U
undee72Z is offline
67 wiring diagram JOHNRSWEAT Electrical & Wiring 2 May 5th, 06 07:44 PM
Wiring Harness Help! tim68rsss Electrical & Wiring 2 Nov 28th, 05 05:08 AM
Rewiring the car... mbmmca Electrical & Wiring 13 Nov 23rd, 05 12:27 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
