Wiring Harness- Should/Can I do it? - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 26th, 06, 10:02 AM Thread Starter
I have a 67 Camaro Conv 6 cyl with an automatic on the column and idiot lights. While I can do some basic things without totally screwing them up, I am not an electrical wizzard.
The wiring in my car is original and is dry. Bubba was there as there is quite a bit of dried electriical tape hanging down as well as some wiring plugs and clips. I was thinking of replacing the dash harness and maybe the rest of the wiring. How difficult is this? Does it require dash removal?
I was looking at Lectric Limited. ZThey want $375 for the dash harness, $86 for the engine, $149 for the front and $120 for the rear.
Any comments would be appreciated.
Joe
joemac8 is offline
post #2 of 6 (permalink) Old Jul 26th, 06, 11:56 AM
Christropher
Re: Wiring Harness- Should/Can I do it?
Go with American Autowire harnesses.
Christropher
...in pieces still.
clwilcox33 is offline
post #3 of 6 (permalink) Old Jul 26th, 06, 12:00 PM
George
Take a look at American Autowire for your body harnesses. They have direct bolt up OEM harnesses or slightly modified ones (if you want to upgrade to HEI, electric fans/pumps, etc). I went to MAD Electrical http://www.madelectrical.com/index.shtml and totally redid my engine harness with numerous upgrades (HEI, 94 volt alt, headlight relays, etc). I followed the excellent instructions and had no problems, and I saw a big improvement. Mark may be a little hard to get a hold of, but he stands behind his products and will talk you through any issues you may have. My headlights and dash lights are much brighter now.
'67 convertible 210HP 327/Powerglide (not anymore!)
GunnerV is offline
post #4 of 6 (permalink) Old Jul 26th, 06, 01:46 PM
Brad
I used www.wiringharness.com That is M&H electrical fabricators. They offer stock and can add any upgrades you want. The harnessess are in the original colors to. All straight forward swaps.
68 Camaro, HOT LS3, tremec 6 speed, vintage air, 17 inch tourque thrust II, CPP discs, 3.73 posi, Autometer gauges, painless harness
Brad74 is offline
post #5 of 6 (permalink) Old Jul 26th, 06, 01:55 PM
3 questions to ask..
Can you use a screwdriver.. are you proficent with it??
Do you know what wire strippers are.? the ones you strip wires with.. not the womanly kind.
and finaly can you follow directions.??
if youve answered YES to all 3 questions.. do it yourself.. we all have the capacity to learn. Take your time, follow the directions and everything will work out fine. This is rewiring a car not neonatal brain surgery..
Good Luck.
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #6 of 6 (permalink) Old Jul 26th, 06, 03:12 PM
Jerry Cox
There is one of the american autowire body harness kit on ebay rite now and it is buy me now for $429 and 20 S&S. I have the same harness kit and that is the way to go if you are every going to upgrade the car. Good luck Jerry
68 Red with Red & white interior, 383, Offenhauser Crossram, 700R4, Ocala FL
Ocala67RS is offline
67 rs wiring harness 67ssrs350 Electrical & Wiring 2 Apr 2nd, 06 07:32 PM
Wiring Harness Help! tim68rsss Electrical & Wiring 2 Nov 28th, 05 05:08 AM
New wiring harnesses - help please! Eric Kammerer Electrical & Wiring 3 Jun 22nd, 05 09:48 AM
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 06:36 PM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
