LED lights - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 26th, 06, 06:53 PM Thread Starter
LED lights
I purchased a couple LED's from autolumination.com..
http://autolumination.com/images/aut...44_2w_mark.jpg
to use in the overhead dome and rear of the console. When trying them in the console, no light was produced and one first one caused a small spark. The other I tried by quickly inserting and then trying again flipping around 180. Same thing, it made a little snap and no light at all either way. I don't think the bulb casing was arching anywhere since I had the rear console lens out while doing this and the wires/brackets looked good. It worked fine both before and after this with the old incandescent bulb. Could this be a problem with the car or is it the bulb?
dsailer is offline
post #2 of 3 (permalink) Old Jul 26th, 06, 07:24 PM
Re: LED lights
That 'rectangular case' has a metallic paint on it. It will cause an ark. They only work ONE WAY, so you have to test both ways. Hold in your door light button to keep interior lights off until you get the bulb inserted and seated well where its not touching the casing.
See articles:
https://www.camaros.net/forums/showth...ght=Superstars
https://www.camaros.net/forums/showth...light=dome+led
and
Brian Lewis is offline
post #3 of 3 (permalink) Old Jul 26th, 06, 08:06 PM Thread Starter
Re: LED lights
yes, I tested them both ways and not in the dome but in the console with the lens out so there wasn't anything around to arch onto.
dsailer is offline
Has anybody used these LED tail lights DOUG G Electrical & Wiring 2 Jun 3rd, 06 12:42 PM
American Autowire LED tail lights! Lucky68 Electrical & Wiring 0 May 4th, 06 07:28 PM
dse led lights for a 69 camaro importkiller69ss Interiors 3 Jan 7th, 06 05:19 PM
69 Lights - what lights come on when? Frost Green 69 Electrical & Wiring 8 Oct 6th, 05 09:45 PM
no parking or hazard lights camaro man Electrical & Wiring 3 Jan 21st, 04 06:49 AM
