Hey its me again..the rookie with all the questions. WHAT is this? - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 28th, 06, 10:35 PM Thread Starter
Jamie
Sorry for so many posts...and for all those that are going to come in the future...but I love you guys! Thanks for all your help thus far.
What is this? I thought a light went in there, but it doesn't look like any of the others. It looks like some type of button.
As you can see, this fixture goes in that hole right above the e-brake pull handle.
1969 Coupe - Work in progress -
jumpmaster is offline
post #2 of 7 (permalink) Old Jul 28th, 06, 11:27 PM
Eric
Re: Hey its me again..the rookie with all the questions. WHAT is this?
Courtesy light. It goes in that hole in the picture. There should be one on the other side just like it. It is spring loaded to hold the light bulb.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #3 of 7 (permalink) Old Jul 29th, 06, 05:21 AM
Charles
Yup, what ept000 said. that lamp housing fits into that bracket and a bulb goes in it. underdash courtesy lights 100% sure.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 7 (permalink) Old Jul 29th, 06, 05:58 AM
standard on all verts.
Guys, were these available or ever used on coupes?
I didn't think so, but his sig only mentions a 69 coupe.
post #5 of 7 (permalink) Old Jul 29th, 06, 07:16 AM
They were part of the RPO ZJ9 (auxiliary lighting group) available to all cars, which consisted of the ashtray light, courtesy lights, glove compartment light, trunk light and underhood light. Hope this helps, RonM.
RonM is offline
post #6 of 7 (permalink) Old Jul 29th, 06, 11:16 AM Thread Starter
Jamie
well I must have the RPO ZJ9 because I have a connector for all those lights RonM just described. And mine is a coupe.
post #7 of 7 (permalink) Old Jul 31st, 06, 07:59 PM
Send a message via Yahoo to chrislwhite
My '68 convertible has these as well. Make sure you use bulbs specifically rated for courtesy lights. None of the sockets had bulbs when I got mine. I tried some extra bulbs I had in the toolbox (single filament reverse light bulbs) and blew a fuse when I plugged the second one in!
One problem I need to troubleshoot- the courtesy lights stay on even when the doors are closed and the dome override is off. I tested the voltage before I blew the fuse. I had 12V when the door was open, and about .3 volts when the door was closed. I haven't tested it since I replaced the fuse and wired up the stereo cassette deck (I used the orange for the deck's memory lead). Any thoughts? Probably an unwanted ground according to this thread:
https://www.camaros.net/forums/showthread.php?t=82901
chrislwhite is offline
new car lots of questions gieske's71nova Engine 4 Jul 13th, 06 04:37 AM
Dana 60 questions bravewink Transmission & Driveline 6 May 10th, 06 06:44 AM
Newbie with Questions ilikecamaros Camaro Tech 4 Nov 14th, 05 07:57 AM
hey every one im new here just got my camaro and have a fiew questions twixterz27 Camaro Tech 7 Jul 15th, 05 02:20 PM
700R4 converter questions z/27 camaro Transmission & Driveline 9 Feb 11th, 04 06:45 AM
