92 Chevy Lumina Signal Switch - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 29th, 06, 02:34 PM Thread Starter
Sorry for the Lumina question. I cant find any good discussion sites for this. Im replacing my parents turn signal switch and I noticed the original switch has two wires that run somewhere near the ignition. Its hard to tell. The replacement switch does not have such wires. What do you suppose that is for and if its important :P
thanks
srober76 is offline
post #2 of 3 (permalink) Old Jul 29th, 06, 03:39 PM
ZZ_430's Avatar
Re: 92 Chevy Lumina Signal Switch
Are they 2 small white wires?
If so, those are the Pass Key wires from the ignition lock cylinder. They are separate from the turn sig switch.
Yes, they are important. Without them the car won't crank (or start). This is a good time to check them to see if they are ready to break. (Very common).
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 3 (permalink) Old Jul 29th, 06, 04:48 PM Thread Starter
Well the car started fine without them hooked up. I suppose they could also be to the hazard or the horn since they both go up in the general area. I managed to pull both wires from the harness and insert them in the same holes in the new harness so they are now hooked up either way.
I hope this fixed the problem. My brother who just started driving 6 months ago was a little to agressive with the signal arm and messed them up. Ever since then if the battery would randomly die if the arm was left in the on position even with the fuse pulled. Smoke would also sometimes come from the column and appears to be a common problem with Luminas signal switches.
Guess ill find out tomorow if the battery is dead :P
srober76 is offline
Wiper Switch Question mjm7496 Electrical & Wiring 6 Apr 5th, 05 10:41 AM
69 Headlight Switch Joe G Electrical & Wiring 3 Apr 2nd, 05 07:05 AM
cooling fan switch Kiko Heating & Cooling 4 Sep 19th, 04 09:26 AM
Alien signals from 1000 light years away Brian Lewis Bench Racing 4 Sep 3rd, 04 06:14 AM
auto shifter/neutral safety switch question Brad74 Camaro Tech 1 Jul 5th, 04 09:04 PM
