wiper motor wiring - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 30th, 06, 08:19 PM Thread Starter
wiper motor wiring
Can any one tell me what the wires are supposed to be for the wiper motor on a 69? I can't find a diagram that I can follow. I have either a short or a loose wire somewhere but I don't know what each wire should do.
BT69chevy is offline
post #2 of 12 (permalink) Old Jul 30th, 06, 10:17 PM
Re: wiper motor wiring
there is a member here that has made some of the best wiring diagrams i have ever seen, better than most manufacturers make today
do a search for my user name and wiper motor or something like that
i know he sells them (really cheap) but cant remember his user name
oh and your lucky he only has them for 69's right now, but the wiper wiring is all the same so i got lucky...
400bird is offline
post #3 of 12 (permalink) Old Jul 30th, 06, 10:46 PM
madmax87's Avatar
Is this what your looking for?
madmax87 is offline
post #4 of 12 (permalink) Old Jul 30th, 06, 10:57 PM
Heres a couple of pics,
http://www.chevelles.com/forums/atta...achmentid=1266
http://www.chevelles.com/showroom/data/500/70wprmtr.jpg
Off Black wire is grounded.
Low Black and Lt blue wires are grounded.
Hi Lt blue wire is grounded.
Wash Dk blue wire is grounded.
Pushing the switch from off sets the switch to low speed and grounds the Dk blue wire.
2-Run solenoid. The Lt blue wire is grounded to lock out the park (mechanically prevents the wipers from being driven to the park position) and close the run/park switch.
3-Shunt winding. This winding is parallel to the armature winding.
4-Series winding. This winding is in series with the armature and shunt windings.
5-Run/Park switch. Closed when run solenoid is energized (Lt blue wire grounded). Also closed when run solenoid is de-energized and wipers not in park position.
6-Wash pump start coil. When the Dark Blue wire is grounded this coil latches the wash pump for one wash cycle.
7-Shunt winding resistor. The shunt winding grounds thru this resistor during high-speed operation and is bypassed (Black wire grounded) during low speed and park.
8-Wiper motor fuse (25 amp) in fuse block. Has +12 VDC when ignition switch is in run or accessory position.
Greg U
undee72Z is offline
post #5 of 12 (permalink) Old Nov 4th, 10, 08:03 AM
kevin
Where do those other wires in the picture (yellow& white, and orange or red) with the open ended ("U" shaped) terminals go?
harddock is offline
post #6 of 12 (permalink) Old Nov 4th, 10, 08:53 AM
kevin
Where do those extra wires in the photo go? (yellow/white, And either the orange or red)
harddock is offline
post #7 of 12 (permalink) Old Nov 4th, 10, 09:03 AM
The coil.
john68 is offline
post #8 of 12 (permalink) Old Dec 18th, 14, 05:42 AM
JIMMY
I have the wires connected as indicated & have power to lt blue, drk blue & yellow. Ground is hooked up but motor or pump will not run. I bypassed switch & still nothing. Is this a ground problem? Motor makes no noise & fuse is good.
Thanks anyone!
jim ray is offline
post #9 of 12 (permalink) Old Dec 18th, 14, 07:21 AM
Jeff
yellow69RS's Avatar
Wiper motor is hot feed at all times the key is on. The switch grounds various wires to get it to perform selected function. Undee72 Z has a list above.
Jeff
yellow69RS is offline
post #10 of 12 (permalink) Old Dec 18th, 14, 08:38 AM
If this grounding plate isn't installed on the back side of the wiper switch the wipers won't work. http://www.rickscamaros.com/camaro-h...late-1969.html
BPOS is offline
post #11 of 12 (permalink) Old Dec 19th, 14, 05:56 AM
JIMMY
If I use a jumper wire from switch housing to a good ground, this should tell me if all is working and if so I should order grounding plate, Correct???
jim ray is offline
post #12 of 12 (permalink) Old Dec 19th, 14, 09:16 AM
It will help narrow things down. Could still be a bad motor or a missing ground strap on the motor mounting rubber washer. http://www.rickscamaros.com/camaro-w...1967-1992.html
BPOS is offline
Wiper motor and Cig lighter inop MD396 Electrical & Wiring 2 Jun 14th, 06 09:35 AM
Windshield Wiper Pressure Seakane Camaro Tech 13 Jun 13th, 05 11:04 AM
windshield wiper motor does not work hobackriver Electrical & Wiring 5 Jul 17th, 03 04:52 AM
Calling all wiper arms! coach420 Body Shop 17 Jun 19th, 02 07:00 AM
wiper motor problem???? hideaway Electrical & Wiring 2 Jan 6th, 02 03:21 PM
