67 horn problem - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 30th, 06, 10:07 PM Thread Starter
67 horn problem
I have read past posts and I am still a little confused.
My horns don't work.
1) At first I could hear the clicking at the relay but it doesn't click anymore.
2) I put 12 volts to both horns from the battery and they both are operational.
3) I have checked wiring on horn relay and it is as pictured on other posts plus I haven't played with it since it was working so I assume it is wired correctly.
4) I checked power at the black lead in the Horn relay it has power all the time.
5) The green wire never has power.
Could it be the horn relay itself, I have replaced it once not too long ago, but have since had the car rust proofed.
Help!
67RS RAG is offline
post #2 of 4 (permalink) Old Jul 31st, 06, 12:16 AM
Re: 67 horn problem
Have you seen this thread w/pic?
https://www.camaros.net/forums/showthread.php?t=60844
When the small black is grounded, power is applied to the green. Try running a jumper from the small black terminal to a good ground to determine if the problem is the relay or in the column.
Greg U
undee72Z is offline
post #3 of 4 (permalink) Old Aug 1st, 06, 02:35 PM Thread Starter
Re: 67 horn problem
I gounded out the black lead and no power to the Green wire. By the way I did this with the ignition off. So does this mean it is a bad horn relay?
67RS RAG is offline
post #4 of 4 (permalink) Old Aug 5th, 06, 10:47 PM Thread Starter
Re: 67 horn problem
Thanks undee, I replaced, acutally my son replaced horn relay everything works, This threw me for a loop because I replaced it less than a year ago and didn't think the relay would be the cause!
67RS RAG is offline
68 horn button assembly question Jerry's68ss Electrical & Wiring 21 Jun 5th, 11 07:26 PM
67 deluxe horn assembly diagram/help needed 67FamilyFun Electrical & Wiring 7 Aug 2nd, 06 06:17 PM
Horn won't sound! chassisboy Electrical & Wiring 2 Feb 7th, 04 01:18 PM
Horn Troubleshooting KWIK 69 Electrical & Wiring 3 Jul 3rd, 02 05:04 AM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 05:10 PM
