67 wiring problems - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 31st, 06, 12:54 AM Thread Starter
67 wiring problems
Hey Guys,
I am restoring a 67 RS camaro in Melbourne Australia.
After cleaning up all the wiring, I have started to install it and have come across the following issues:
With the brakes applied, right turn signal - brake light goes off left hand side (it the right brake stays on correctly when signalling left.
Hazards work as normal, but when brake is applied the rear lights stay on (stop flashing) and the fwd parkers stay on as long as the brake pedal is depressed. As soon as the pedal is released they flash as normal.
With instrument lights on, the turn signal lights in the cluster come on aswell - (and the instrument lights dont appear to be very bright.
No brake warning light in ignition mode - i have gen, temp and oil though.
Any advice on how to rectify these would be great.
Thanks in advance,
Leon
leons454 is offline
post #2 of 4 (permalink) Old Jul 31st, 06, 10:33 AM
Denis
Re: 67 wiring problems
Check that you didn't squish the wiring harness in/around the steering column.
deejaygee is offline
post #3 of 4 (permalink) Old Jul 31st, 06, 11:49 AM
geneo
check dash ground as well
gene_sc is offline
post #4 of 4 (permalink) Old Jul 31st, 06, 12:18 PM
The hot side wiring for the brake light is shared with the temp & oil lights, and the fuel gauge. The brake light problem is probably separate from your other ones, and relating to the ground side of the circuit, which is the wire going to the switch on the ebrake.
Check the dash ground for sure. It goes by the high beam indicator. When you put the high beam indicator together, did you put the red lens on first? Putting this together in the wrong order will kill the dash ground.
Might be worth checking the tail light ground as welll. I usually put a star washer under 2 nuts on each tail light, this cuts through the paint and makes a good connection.
Looking for pics of wiring for 67 console guages oakster Electrical & Wiring 4 Apr 29th, 06 05:37 PM
68 Wiring Problems cap1994 Electrical & Wiring 6 Dec 12th, 05 06:41 PM
Installing console gauges and wiring. Questions... jumpmaster Electrical & Wiring 7 Aug 23rd, 05 05:36 PM
starter wiring problems! 86irocz Engine 13 Nov 10th, 04 03:42 AM
Wiring problems with console fuel gauge Jeff H Tech 2000 1 Nov 15th, 99 04:40 AM
