What do I need to hook up factory console gauges? - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 29th, 06, 04:18 AM Thread Starter
Marc
mnm99's Avatar
How accurate are the 69 console gauges?
I'm looking to get a console and really like the stock look of the console gauges. How good are they?
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #2 of 14 (permalink) Old Jul 29th, 06, 05:44 AM
Harry
dawg's Avatar
Re: How accurate are the 69 console gauges?
they are not as accurate as autometer gages.
but they will get you in the ballpark
434 stroker
US Navy retired
dawg is offline
post #3 of 14 (permalink) Old Jul 30th, 06, 03:29 AM Thread Starter
Marc
mnm99's Avatar
Are they all electrical?
mnm99 is offline
post #4 of 14 (permalink) Old Jul 30th, 06, 06:35 AM
Bob
Oil pressure is mechanical,all the rest are electric.
bob
Bgonz 69 is offline
post #5 of 14 (permalink) Old Jul 30th, 06, 07:46 AM
DjD
DjD's Avatar
Dawg I don't know how you can say that... The factory are just not as detailed in what degree the temp is or pressure you are at. From the auto meter and factory I have in mine right now both temp and oil pressure are very consistant with each other.
I've been running both just to satisify myself that I can trust the factory and I do. My intent is to remove the auto meter from th ecar.
...Dennis
DjD is offline
post #6 of 14 (permalink) Old Jul 31st, 06, 06:50 AM Thread Starter
Marc
mnm99's Avatar
What company is the best to buy from? Are some better than the others? Do I need a harness or can I wire it like any other gauge? can I buy a 68 console and put the 69 gauges in it or should I buy the 69 console? Sorry for all the questions.
Also what do I need for the fuel gauge? At one point I will hook it up and put the tach in the dash.
mnm99 is offline
post #7 of 14 (permalink) Old Jul 31st, 06, 04:21 PM Thread Starter
Marc
mnm99's Avatar
I have these wires that go to my B&M shifter. Some of them are terminated at the shifter. Are these the wires I need for the console gauges.
-Big purple
-Small green
-Small white
-Big purple with a white stripe
-Pink
-Orange
-Gray
mnm99 is offline
post #8 of 14 (permalink) Old Jul 31st, 06, 04:22 PM Thread Starter
Marc
mnm99's Avatar
-Big purple
-Small green
-Small white
-Pink
-Orange
-Gray
mnm99 is offline
post #9 of 14 (permalink) Old Jul 31st, 06, 04:54 PM
Jerry Cox
First of all, all of the aftermarket console are the same. I just brought a complete 68 console off of ebay for 319.00 plus shipping ($20). The body of the 68 and 69 console and the way they mount are the same, the forward and shift trim plate are different. You will not need the forward trim plate with the gauges. What are you going to use for a shifter (factory or after market)? Now from looking at the wire you have listed it is for a console without gauges;
Big purple power for neutral switch
Big purple/white stripe starter side of neutral switch
Pink power for backup lights
samall green light side of backup lights
Gray console/dash lights
Orange console rear courtesy light power
Small white ground for rear courtesy light
None of these are for gauges. If you are going to convert to factory gauges, you will need along with the gauges, the factory console harness for factory gauges and a convertion harness for you main harness to make it a gauges type harness. You will need a new printed circuit for the rear of the dash pod and the tach. If you are going to do this PM me and I will put you in touch with the guy I got all my stuff from and it will save you a couple hundred dollars over what the guys at classic, rick, and NPD charges. Good luck Jerry
68 Red with Red & white interior, 383, Offenhauser Crossram, 700R4, Ocala FL
Ocala67RS is offline
post #10 of 14 (permalink) Old Jul 31st, 06, 05:10 PM Thread Starter
Marc
mnm99's Avatar
Sent you a PM.
mnm99 is offline
post #11 of 14 (permalink) Old Jul 31st, 06, 08:11 PM
madmax87's Avatar
Re: What do I need to hook up factory console gauges?
Big purple and Big purple /wht should be your neutral safety sw. Not sure about the others on a 68.
madmax87 is offline
post #12 of 14 (permalink) Old Aug 1st, 06, 06:41 AM
click's Avatar
click is offline
post #13 of 14 (permalink) Old Aug 1st, 06, 07:39 AM
DjD
DjD's Avatar
mnm - I merged your two threads here since they were going in the same direction...
...Dennis
DjD is offline
post #14 of 14 (permalink) Old Aug 1st, 06, 09:53 AM Thread Starter
Marc
mnm99's Avatar
Thanks..
mnm99 is offline
B/M Z gate in factory console Brackneyc Transmission & Driveline 0 Jun 19th, 06 06:41 PM
69 Console Gauges Questions hotrodz/28 Electrical & Wiring 2 Apr 26th, 06 08:40 AM
Console Gauges Repo vs Original dschribs Interiors 17 Jul 29th, 03 01:48 AM
console gauges beagle113 Tech 2000 2 Nov 9th, 00 02:00 PM
