Changing light bulbs in dash 68 Coupe - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 2nd, 06, 04:29 PM Thread Starter
The lights in my dash are either too dull or not working (blown). How do you go about changing the small bulbs in the dash? Can you access them from the front by removing the screws on the front panel and removing it, or do you have to go under the dash? These are for the speedo and the gas gauge.
I know this is pretty basic but this 68 is totally new to me. I have had 3 69s.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #2 of 8 (permalink) Old Aug 2nd, 06, 05:05 PM
john
wagonman's Avatar
Re: Changing light bulbs in dash 68 Coupe
the best way is to go under the dash.(isnt easy)
otherwise i will also remove the steering column bolts under the dash.
put rags on top of the column to prevent scratches from the gauge cluster.then remove the cluster.dont forget the speedo cable...be careful not to pull to much on the wires....
wagonman is offline
post #3 of 8 (permalink) Old Aug 2nd, 06, 05:10 PM
The bulb sockets pop of the back of the cluster after turning them 1/4 turn counterclockwise. You have to pull the cluster out or go under there and reach for em. It's not an easy reach.
The "illumination bulbs (4 of them) are in a straight horizontal line through the middle of the speedo and fuel guage. Stock bulbs are type 194, and are 4 watt bulbs. They make a 7 watt bulb, I don't know the # but a good parts counter guy can find them in the book. I use the 7's, they are much brighter and it hasn't hurt anything.
Here's a pic of the back of the dash:
post #4 of 8 (permalink) Old Aug 2nd, 06, 05:41 PM
Farm Boy's Avatar
If the speedometer cable is hanging you up from pulling the instrument cluster you can disconnect it under the car to gain some slack. Some of these cars have a two piece speedometer cable which can be easily separated. Look for a connecter by the driver side frame rail.
Farm Boy is offline
post #5 of 8 (permalink) Old Aug 2nd, 06, 06:33 PM Thread Starter
Thanks guys I will give the reach a try first then if all else fails I will pull it.
JimM: I take it that the four open holes in the upper half of the picture are where the bulbs go. Thanks for the pic, it is worth a thousand words. One more question. does the speedo cable clip into place or is it threaded on the back. My 69s had a clip. 7 watts it is.
Stewie is offline
post #6 of 8 (permalink) Old Aug 2nd, 06, 07:33 PM
Christropher
Those open holes aren't holes, they are black plastic sockets that "screw" into the cluster 1/4 turn.
Christropher
...in pieces still.
clwilcox33 is offline
post #7 of 8 (permalink) Old Aug 2nd, 06, 07:38 PM
The top 4, pretty much in a line straight across.
The parts man will probably have to go in the back of the "old book" there will be a list of bulbs by type, they do make a 7 watt "bayonet" bulb but I can't recall the number.
The speedo cable on my 68 screws in.
post #8 of 8 (permalink) Old Aug 3rd, 06, 05:57 AM Thread Starter
Now that I look closer at the picture I see they are actually sockets.
I will have to try the one local dealer who still has the old books.
Thanks again.
Stewie is offline
Nada value on a 68 coupe... philtheskipper Bench Racing 14 Dec 23rd, 05 10:49 PM
68 rear light plugs.........help longhorn Troubleshooting 7 Oct 28th, 05 07:47 AM
How to remove gas tank in a 68 coupe. ray moore Body Shop 12 Oct 23rd, 05 04:46 AM
dash lights on whenever ignotion is on--also GEN light on all the time backfire Troubleshooting 1 Sep 16th, 00 02:54 PM
1984 berlinetta digital dash wont light up please help!!! bonifacem Troubleshooting 1 Jun 25th, 00 06:34 PM
