Help! 67 twin fan setup with relays and ajustable temp switch! - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 3rd, 06, 05:38 AM Thread Starter
At first I had twin spar fans one relay and temprature sensor working fine for two months.Then the wires melted together and the conector and relay melted?So I cut out all the wireing and started over with 2 relays one for each fan and a new adjustable temp switch.No on and off switcth I want the fans to come on bye them self.Heres what I did the red from the relay goes to battery power the black to ground the yellow goes to the fans from the fan out is a fuse tied to ground.Now the white wire from the relay goes to the adjustable temp sensor to horn relay?What am I missing I looked it up could not fined it.Any drawing of this set up or tell me how to do this Please and Thanks for your help!
FastFred is offline
post #2 of 5 (permalink) Old Aug 3rd, 06, 09:14 AM
Re: Help! 67 twin fan setup with relays and ajustable temp switch!
What kind of temp sensor (your new adjustable temp switch) ? Do you want any manual control of the fans? Determine that first before doing any wiring. I helped another member, but it was only one fan.
https://www.camaros.net/forums/showthread.php?t=80771
Greg U
undee72Z is offline
post #3 of 5 (permalink) Old Aug 3rd, 06, 10:34 AM Thread Starter
Greg I saw that post you are the one its the flexlite 31148.I went to separate relays for the fans for sucerity .Did not want to have a fire.can you post a picture of it being wire with separite relays and one adjustable switch to twin fans.I want the fans to come on by the sensor and cut off by the sensor.
FastFred is offline
post #4 of 5 (permalink) Old Aug 3rd, 06, 11:50 AM
Here you go, the fans will be off when the key is off, will be on only when key is on and temp is over preset value.
For battery power, use the horn relay if like factory wiring.
For IGN power, use IGN terminal at fuse box.
Use 10g wire for red wires in pic.
Use 16g wires for blue wires in pic.
Greg U
undee72Z is offline
post #5 of 5 (permalink) Old Aug 4th, 06, 04:47 AM Thread Starter
Thank You Thank you Thank you I got one to work yesterday relooked at you diagrams and got one to work the other kept blowing the fuse.So now I can see whats wrong Thanks a millonnn!!!
FastFred is offline
