Dash Harness - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 6th, 06, 08:01 PM Thread Starter
Dash Harness
Hello, and thanks in advance for your help. I have a 69 Camaro with console gauges I have been playing with the car now for three years doing upgrades etc. I installed all new wiring, engine, dash harness etc. My question is: I have six male connecters left from the dash harness they are as follows:
One that is a two male connecter one male has two pink wires the other is green.
One that is a two male connecter one male with a yellow the other with a black (ground?)
One that is a two male connector one male with a purple the other with a purple (12 Gauge wire)
One two male connector one male that is orange the other is white
One four male connector with a lavender, Pink, red and two browns together (one 14 gauge the other 12 gauge)
One two male connector one orange the other red (12 Gauge wire)
What are they for where do they go?
Dave Brinson is offline
post #2 of 12 (permalink) Old Aug 6th, 06, 08:24 PM
Jonesy's Avatar
Re: Dash Harness
right off the top of my head:
One that is a two male connector one male with a purple the other with a purple (12 Gauge wire) - Neutral safety switch
What are the cars options?? Does it have auto or manual? Gauges?
Need all the info about the car as some of these may be for options.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #3 of 12 (permalink) Old Aug 6th, 06, 08:29 PM Thread Starter
Re: Dash Harness
It is a four speed car it has console gauges. So does a four speed car have a nutural saftey switch?
post #4 of 12 (permalink) Old Aug 6th, 06, 08:30 PM Thread Starter
Re: Dash Harness
** Neutral not nutrul
post #5 of 12 (permalink) Old Aug 6th, 06, 08:32 PM Thread Starter
Re: Dash Harness
I also have two single orange wires any idea?
post #6 of 12 (permalink) Old Aug 6th, 06, 08:41 PM
madmax87's Avatar
Re: Dash Harness
Well heere's a couple,
yellow/blk = radio
or/wht = brake pedal sw
Now the purple wires, if one is purple and the other purple/w than this is for your neutral sw. If you have a 4-speed it goes to the clutch depress sw. A auto on floor is goes to the shifter, an auto on column there should be a place on the column for it.
The 2 pink & green. Is 1 pink 12ga, one 20ga, and the grn 14 ga? My drawing show the grn as a ppl and go the dir sig flasher.
Still working on the others...........
Single or is cig lighter and glove box lamp
madmax87 is offline
post #7 of 12 (permalink) Old Aug 6th, 06, 08:49 PM Thread Starter
Re: Dash Harness
Thanks!
The two pink with green are all same gauge wire msybe 16-18 Gauge?
post #8 of 12 (permalink) Old Aug 6th, 06, 08:55 PM
click's Avatar
Re: Dash Harness
try this, it might help you out
click is offline
post #9 of 12 (permalink) Old Aug 6th, 06, 09:09 PM
madmax87's Avatar
Re: Dash Harness
Jim, I think he needs the dash harness printout. My scanner on the fritz.
madmax87 is offline
post #10 of 12 (permalink) Old Aug 6th, 06, 10:12 PM
madmax87's Avatar
Re: Dash Harness
Dave, I'm just looking at a new wiring harness I got from Factory Fit for a 69 console gauge 4 speed. I see the harness (2 pink & green) no idea as yet. The one I can't seem to find is the 4 plug you talk about. I think it's the heater control plug. I'll be taking mine apart tomorrow and replacing with the new one so I'll keep a close look for these and let you know if someone doesn't come up with them.
madmax87 is offline
post #11 of 12 (permalink) Old Aug 7th, 06, 04:34 AM
Jonesy's Avatar
Re: Dash Harness
Actually I meant the purple wires are for the clutch safety switch (or whatever it's called)
Jonesy is offline
post #12 of 12 (permalink) Old Aug 7th, 06, 06:51 AM Thread Starter
Re: Dash Harness
Thanks, I be waiting.
Need to confirm two wires on 69 dash harness turn signal connector Eric Kammerer Electrical & Wiring 1 Aug 5th, 06 10:29 PM
1968 Dash Harness LB1 Electrical & Wiring 3 Jun 10th, 06 07:11 PM
Is the Under dash wiring harness fron Classic Ind worth it? POCKER Electrical & Wiring 2 Apr 24th, 06 10:02 AM
1969 Dash Harness SKIPS69 Electrical & Wiring 0 May 23rd, 05 10:14 PM
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 06:36 PM
