HEI Install, dump my current Ignition Box? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 11th, 06, 05:05 AM Thread Starter
Send a message via MSN to ExileMo Send a message via Skype™ to ExileMo
Gents,
I am converting my 67 350 to HEI, but have a little spaghetti wiring left over from previous owner. I converted my old stock 69 with no problems, but this time is a little different.
Current setup uses Crane HI6 Fireball Ignition Box and PS91 External Coil.
So I assume dump the old Coil, but what about ignition box? I am a little confused as whether I should keep, dump or replace it. I can't find much info on the box, except for simple sales info.
Comments?
Mo West
67 RS Convertible...
ExileMo is offline
post #2 of 2 (permalink) Old Aug 11th, 06, 07:49 AM
Re: HEI Install, dump my current Ignition Box?
That is a very good CDI box that you have. Why in the world would you want to swap over to an HEI??? Your Crane set up is a much better proposition-built in rev limiter, multiple spark, hotter ignition... Plus, the HEI has a larger cap and may, or may not, fit without indenting the firewall.... I am currently running an HEI distributor that has been gutted. I am only using the magnetic pick up to fire my Crane Hi-6 box. I am currently looking to dump my HEI and will as soon as I can find a suitable distributor that will signal my Crane box, and has a vacuum advance set up on it.
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
Update on 505 Tall Deck swap Dominate67 Performance 1 Jul 5th, 06 10:31 AM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
hei install in 68 BBCamaro Troubleshooting 3 Jul 7th, 02 05:48 PM
HEI tach install greg's rs Electrical & Wiring 2 Sep 11th, 01 11:21 AM
GM "HEI" ignition swap ORENCH Performance 5 Nov 22nd, 00 12:55 PM
