Turn Signal Problems - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 13th, 06, 04:20 PM Thread Starter
1967, right side blinks, slowly. Left side does not blink, however all bulbs light, front and rear. Thinking flasher, but it seems odd that one side works and the other side does not. Am I correct in assuming that there is only one flasher?
KZOO/67RS/SS is offline
post #2 of 2 (permalink) Old Aug 13th, 06, 07:57 PM
Re: Turn Signal Problems
hmmm, don't remember if 67's had hazard lights.... if they do, that flasher would be in the fusebox.
The turn signal flasher is clipped to the lower dash lip, just to the right of the guages, directly under the lighter and ignition.
Also check for bad grounds at all foiur corner lights.
69 Camaro Turn Signal Cancelling Cam billscamaros Brakes, Suspension & Steering 2 Mar 20th, 06 06:00 PM
Help with 68 Turn Signal Mechanism sallman Camaro Tech 2 Aug 22nd, 05 08:42 PM
Dimmer Switch & Turn Signal Lights Guage Lights rookie68camaro Electrical & Wiring 1 Mar 23rd, 05 02:05 AM
light switch and turn signal roho29 Electrical & Wiring 1 Mar 30th, 04 06:15 AM
'67 Taillight & Turn Signal Electrical Problems macasiebjj Electrical & Wiring 3 Nov 13th, 03 05:57 PM
