Bulkhead Connector Replacement - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 13th, 06, 10:17 PM Thread Starter
one of the ears on my bulk head connector is broken and I am conteplating repalcing it. I keep losing power to the car and it won't stay on. I have new connector I ordered a while ago.
Has anybody done this? I will use the old fusebox.
Is there a trick to pulling out pins from old connector and putting them in the new one?
Has anybody rigged up snything to hold the connector from the firewall side on?
67RS RAG is offline
post #2 of 6 (permalink) Old Aug 13th, 06, 10:45 PM
Vintage 68's Avatar
Thumbs up Re: Bulkhead Connector Replacement
The firewall connector will usually stay in place just by the 'goo' applied as a sealer.
The pins can be released fairly easily with a sharp tool to push in the retaining lug and push them out.
There is also a special tool sold by most the major "tool truck" guys to release them. I have several different designs and they all work pretty good.
Be sure to mark the wires and the positions carefully - they are easy to get misplaced
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 6 (permalink) Old Aug 14th, 06, 01:27 PM Thread Starter
Thanks, vintage 68
are these tools used to push the pin out or pull it out. As for the different tools is it a matter of size or design?
67RS RAG is offline
post #4 of 6 (permalink) Old Aug 14th, 06, 09:32 PM
Vintage 68's Avatar
Talking Re: Bulkhead Connector Replacement
Yes - size always matters
The connector tools are used to 'push' the connect back out in the direction of the wire.
These connector do come in various designs based on manufacturer of the connector, but the GM type usually one of the twp most common that release just a tag on one side or slide over a barrel shaped connector and depress the two (or more) side lugs to release the connector and allow it to be pushed out.
Many auto part stores will carry the "Lisle" (sp?) brand of auto tools - one of their multi-connector tools is an excellent choice for your tool box.
1968 Convertible
Some trucks
post #5 of 6 (permalink) Old Aug 14th, 06, 10:14 PM Thread Starter
Thanks Vintage I just spent an hour on the snap on website and couldn't find anything. Your reply was just in time. After visiting there website I guess you are talking about the hexagonal tool that has 6 different "bits" on the end.
I wish their pictures were bigger!
67RS RAG is offline
post #6 of 6 (permalink) Old Aug 14th, 06, 10:21 PM
Vintage 68's Avatar
Originally Posted by 67RS RAG
... I guess you are talking about the hexagonal tool that has 6 different "bits" on the end.
That's the one I use quite often
Mine have a green or a red center body - sorta the Ninja-star-of-death for connectors
1968 Convertible
Some trucks
Bulkhead Markings WildBillyT Tag Team 5 May 31st, 05 07:03 PM
Bulkhead Connector removal houston68 Electrical & Wiring 3 May 10th, 05 06:56 AM
Rear bulkhead markings Bruce68 Tag Team 7 Jan 28th, 05 12:30 PM
"X0" Rear Seat Bulkhead Chalk Mark kjk Tag Team 5 Apr 1st, 03 01:42 PM
X codes on rear seat bulkhead!!?? 69DZ XRAM Tech 2002 5 Jul 13th, 02 01:57 PM
