One wire alternator - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 15th, 06, 06:16 PM Thread Starter
One wire alternator
Hi All just switched to a one wire 100 amp alt.
2 quick questions.
1)At a stop sign volts drop to about 12 and then when I start back up they jump up to 13.8..is that normal.
2)When a hit my turn signal the colt guage drops in sync with the blinker...is that normal as well?
Chris
freebird is offline
post #2 of 2 (permalink) Old Aug 16th, 06, 12:34 PM
Re: One wire alternator
No, it is not. Optimally, you want the battery to be charging at idle also. Causes, could be the alternator brand, pulley ratio, and how it is wired.
2)When a hit my turn signal the volt guage drops in sync with the blinker...is that normal as well?
Chris
If the voltmeter is wired to fuse box turn signal circuit, then yes it is.
Greg U
undee72Z is offline
Charging system, external regulator JimM Electrical & Wiring 15 Jan 21st, 20 09:09 PM
1 Wire - 3 Wire Alternator Question redlines4us Electrical & Wiring 8 Jun 26th, 07 02:16 PM
One Wire Alternator problem freebird Electrical & Wiring 3 Aug 11th, 06 10:06 AM
Ground wire for Alternator 3rail Electrical & Wiring 3 Apr 16th, 06 04:34 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
