can I change the clock position of my alternator ? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 17th, 06, 08:29 AM Thread Starter
Jerry R.
jr68's Avatar
I want to change the clock position of my new internal regulator alternator from 3 to 9. How do I go about this ? Thanks.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #2 of 6 (permalink) Old Aug 17th, 06, 08:50 AM
Re: can I change the clock position of my alternator ?
Loosen the 4 through bolts and turn it. Be careful not to separate the 2 sides of the case to far, or the brushes and springs will get fouled up. Spoken from experience.
greenham is offline
post #3 of 6 (permalink) Old Aug 17th, 06, 09:19 AM Thread Starter
Jerry R.
jr68's Avatar
what about the stud where the bat wire attaches ?
jr68 is offline
post #4 of 6 (permalink) Old Aug 17th, 06, 10:37 AM
Codi's Avatar
When clocking the SI series alt., Mark the case so if a mistake happens, you can realign the case back to the original position. Remove the four hex head screws and turn the portion of the case under the pully/fan only. Do not let the stator or lower case turn as these are where all the electrical connections are located. Clock as needed and replace the four screws.
Daddy's Hot Rod.
Codi is offline
post #5 of 6 (permalink) Old Aug 17th, 06, 10:46 AM
Do not disturb the rear half, nothing needs to be disconnected. You will want to hold the armature shaft in the rear half while you turn the front case. This will prevent the armature from pulling out of the rear bearing and disturbing the brushes when the case bolts are removed.
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #6 of 6 (permalink) Old Aug 17th, 06, 10:57 AM Thread Starter
Jerry R.
jr68's Avatar
thanks guys I'm gonna do it tonight.
jr68 is offline
Alternator Conversion Sixty-Seven rs Electrical & Wiring 3 Jul 2nd, 04 04:16 PM
Clock repair ... this turned out GREAT .. click Electrical & Wiring 5 Jun 25th, 03 10:10 AM
alternator conversion jrager Electrical & Wiring 1 Jun 11th, 02 06:30 AM
Need part # for CS alternator w/ 10 o'clock ear JayBird Electrical & Wiring 1 Feb 20th, 02 07:32 PM
repairing a clock on a 68? 68CMRO Interiors 2 Sep 15th, 01 12:51 PM
