Electric fans and Electric fuel pump? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 21st, 06, 09:04 PM Thread Starter
ENP
I am in the process of wiring up my 69 camaro. I have a Ron Davis radiator with dual fans. I also have a Holley electric fuel pump. Both need to be wired up to the IGN on my fuse box. Can I splice the fan wire and fuel pump wire together and plug it in the IGN?
ENP is offline
post #2 of 6 (permalink) Old Aug 21st, 06, 09:16 PM
madmax87's Avatar
Re: Electric fans and Electric fuel pump?
As long as the fuel pump doesn't draw any significant current and your hooking up the fans signal wires to the IGN, I would think you would be ok. Nice choice on the radiator.
madmax87 is offline
post #3 of 6 (permalink) Old Aug 21st, 06, 09:18 PM Thread Starter
ENP
Holley says the fuel pump only draws 3amps.
ENP is offline
post #4 of 6 (permalink) Old Aug 21st, 06, 09:40 PM
madmax87's Avatar
Shouldn't be an issue. Signal current going to the relays for the fans will be minimal. Sounds like it's a go to me. Anybody else's opinion?
madmax87 is offline
post #5 of 6 (permalink) Old Aug 21st, 06, 10:36 PM
BonzoHansen's Avatar
Yes, the signal wires, not the actual power feed wires. Pumps & fans need realys.
TC Member #13
BonzoHansen is offline
post #6 of 6 (permalink) Old Aug 22nd, 06, 04:12 AM Thread Starter
ENP
thanks for the input.
ENP is offline
Who's running both electric and fixed fans? mnm99 Performance 13 Jul 6th, 06 01:35 PM
4th Gen electric fans in a 68 - Installed! Poncho Heating & Cooling 2 Jun 24th, 03 06:38 AM
electric fans won`t work 88 iroc-z Troubleshooting 8 Oct 5th, 01 05:03 PM
Relay for electric fans MarkM Electrical & Wiring 7 Jul 28th, 00 01:04 PM
Electric Fans Bob Cam Performance 6 Jun 26th, 00 07:21 AM
