autometer gauges in dash , no signals working - Team Camaro Tech
post #1 of 15 (permalink) Old Aug 22nd, 06, 03:01 PM Thread Starter
Question autometer gauges in dash , no signals working
i took out the factory speedo, and gas gauge out of my 67 , and replaced them with autometer speedo, and tach into the factory housing , i currently have both brake lights , and hazzard lights working , but no signals, i put in little diode type lights for the signals but other than the hazzards they are working neither are the real signals (BODY) i am using the original plug that goes into the factory dash , anybody know how to get them to work pleasw help , thanks chris
1967rsssconv is offline
post #2 of 15 (permalink) Old Aug 23rd, 06, 06:27 PM
Re: autometer gauges in dash , no signals working
Sorry, can't help you, but I have been thinking about this gauge swap myself. Do the guages just drop right in or do you have to mod the guage or console? Good luck with your problem.
1970 Nova 350/alum. heads/650 holley/373 11.03 et w/100 shot
1967 Camaro
lite em up is offline
post #3 of 15 (permalink) Old Aug 23rd, 06, 07:15 PM Thread Starter
it wasnt to bad to do very little trimming , and i epoxied them in it looks great
post #4 of 15 (permalink) Old Aug 24th, 06, 01:40 AM
i believe the turn signals have a separate fuse from the rest of the lights even the emergency flashers
also the turn signal flasher mounts in the general gauge area (im not sure where factory was cause when i got my 67 it was just hanging under the dash from the wiring...) so it may have been disturbed and come unplugged, or just decided that it wanted to crap out...
400bird is offline
post #5 of 15 (permalink) Old Aug 24th, 06, 04:26 AM Thread Starter
ill take a look ,but im pretty sure its not the fuse, i think its a common fuse on 67 but gets its own in 68 and up
post #6 of 15 (permalink) Old Aug 24th, 06, 06:33 AM
Randy
rs1968ss's Avatar
Can you hear the blinker clicking? When I did mine I used a voltmeter to find the correct wires. Turn the blinker on and watch your voltage.
-Randy
rs1968ss is offline
post #7 of 15 (permalink) Old Aug 24th, 06, 08:21 AM
I'm wondering about your "LED" indicators.
LED's operate on 1.8 volts, period. For them to function in a 12 volt circuit, you need a resister in series, tho I don't remember the value.
Radio Shack carries some lil red 12 volt lamps which I used. They don't require any resisters and such, and fit thru a 1/4 inch hole just like an LED.
post #8 of 15 (permalink) Old Aug 24th, 06, 02:15 PM Thread Starter
thanks , i am using the 12 volt radio shack lights not leds they light up fine for the hazzards but nuthin for the signals
post #9 of 15 (permalink) Old Aug 24th, 06, 09:30 PM
Carl
It's been too long, but something keeps making me think that a different flasher unit is necessary when using the LED indicators due to the lighter circuit load.
CarlC is offline
post #10 of 15 (permalink) Old Aug 24th, 06, 09:47 PM
When you turn the blinker on, does it light up but not flash?
That would be a flasher problem.
If nothing even lights up, it could be a bad flasher, otherwise it has to be related to the turn signal switch or the wiring in the column.
The turn signal flasher clips to the underside of the dash below the key and the lighter. The one in the fusebox is for the hazards only.
The brake lights and haxards use all the same wiring as the turn signals.
post #11 of 15 (permalink) Old Aug 25th, 06, 09:55 AM Thread Starter
hey jimM , you did it i found the wires that are supposed to be under the dash for the signal its a purple and brown for anyone else that needs to know , its a new harness and it never had a blinker fuse , go figure , thanks to all that made suggestions i tried them all... and thanks again jimM
post #12 of 15 (permalink) Old Aug 25th, 06, 11:01 AM
your very welcome, my pleasure!
Also 400bird was on the right track, just didn't quite have the specifics. Glad you gotter fixed!
post #13 of 15 (permalink) Old Sep 11th, 06, 03:56 PM
I am doing the same to a 68. Did you use the 5" speedo and tach?
What had to be modified? Thanks
Tom D is offline
post #14 of 15 (permalink) Old Sep 12th, 06, 08:52 AM
Randy
rs1968ss's Avatar
Yes. Here is an old thread with the details:
https://www.camaros.net/forums/showth...ometer+phantom
-Randy
rs1968ss is offline
post #15 of 15 (permalink) Old Sep 26th, 06, 09:34 AM
Thumbs up Re: autometer gauges in dash , no signals working
Thanks RS
The construction of the meters sure has changed. Yours look metal. The new Phantoms are plastic cases and plastic retainers. So you had to trim the two bezel openings from the back to get the guages to fit the holes? You have a very clean looking install.
68 Camaro now sb427 motown<br />01 Lightning
Tommyd is offline
Autometer 5 inch Gauges, need mounting advice ricksvt Interiors 12 Apr 4th, 06 07:43 AM
Power to gauges (Autometer) Liveinaz Electrical & Wiring 5 Feb 8th, 06 05:11 PM
Dash Gauges 2zMax Electrical & Wiring 2 Oct 2nd, 01 11:12 PM
Autometer Console Gauges and Idiot Lights daverichard Electrical & Wiring 4 Aug 15th, 01 04:35 AM
Dash lights not working pakual Troubleshooting 2 Aug 10th, 01 11:07 AM
