Junction block? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 22nd, 06, 03:56 PM Thread Starter
ENP
Junction block?
I am going with a 1-wire alternator in my 69 camaro. I am going to run the alternator wire and the positive battery wire to the junction block. Is this the proper way to do it. I am using new Factory Fit wire harnesses. Also, I was told to unplug the voltage regulator and neatly tape of the regulator harness.
ENP is offline
post #2 of 2 (permalink) Old Aug 23rd, 06, 01:29 AM
Re: Junction block?
It would be better to use a 3 wire alternator. See reasons here
http://www.madelectrical.com/electri...hreewire.shtml
some 1 wire alternators can also be wired as a 3 wire. If you are going to use the 1 wire, wire it to the horn relay. it is the alternators job to power everything in the car and charge the battery, the horn relay is the mid way point between the battery and fuse box.
Greg U
undee72Z is offline
Tonawanda DZ Lawrence Shaw Engine 97 Jul 20th, 06 07:05 PM
68 junction block west 68 Electrical & Wiring 2 Aug 5th, 05 09:05 PM
No Block I.d. Numbers - 427 Copo???? Help gonewacky Engine 5 Jul 3rd, 05 08:23 AM
1968 327 Block Carburetor Tag Team 2 Dec 22nd, 04 04:52 PM
Aluminum Block Info zl1num12 Engine 6 Aug 28th, 03 09:09 AM
