Turn Signal Blowing Fuse - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 26th, 06, 12:34 PM Thread Starter
98 Camaro V6
The fuse for the turn signal just started blowing. No apparent reason.
All the other lights work fine so its confined to the T/S circuit. I replaced the fuse and the hazards work fine which suggests its not the sockets or wiring at the bulb holders.
Also took out the front bulbs and found a lot of grease in the holder. Mystery where that came from. Cleaned them up and ran a functional check and all was working. Drove off down the road and it blew a fuse at the first turn.
Does this sound like the switch?
Any advice on troubleshooting?
DeeGee is offline
post #2 of 6 (permalink) Old Aug 26th, 06, 02:31 PM
Re: Turn Signal Blowing Fuse
Try replacing the bulbs, sometime if they go out it will blow a fuse.if I have to take a wild guess, I'd say pull the turn signal switch and the wiring out of the column, look for some broken insulation that was grounding out a wire. Did you check the rear sockets?
Sytar69 is offline
post #3 of 6 (permalink) Old Aug 27th, 06, 08:40 AM Thread Starter
Yes I checked all the sockets
That could explain why it only happens on the move. Maybe the vibration is causing contact?
What I don't quite follow is that the circuit is good with hazards on. Its also good when stationary and engine off. I can replace the fuse even with a 15A and it works fine. Its just when the car is moving that it blows. Whats different on the circuit when its going that would cause that? Vibration causing a short on a bad wire?
DeeGee is offline
post #4 of 6 (permalink) Old Aug 27th, 06, 10:09 AM Thread Starter
Well I've tied it down further
It blows when you select reverse
I had a similar problem recently with the back up lights. It was blowing the fuse when I selected reverse. I changed the sensor on the transmission and it cured it
Is the back up sensor linked to the turn signal in some way? I guess it could be another bad reverse selector sensor but still dont see the link
Help!
DeeGee is offline
post #5 of 6 (permalink) Old Sep 2nd, 06, 10:21 AM Thread Starter
ttt
DeeGee is offline
post #6 of 6 (permalink) Old Sep 2nd, 06, 07:02 PM
Billy Morris
I had a similar problem. Fuse would blow sometimes. Couldn't find a short.
Then I discovered the turn signal switch spring had broken and was sliding
around in the steering wheel and would ground out occasionally, blowing
the fuse . Hope this helps Billy
morrisclassic is offline
Turn signal fuses keep blowing???? Erik Beckett Electrical & Wiring 5 Aug 26th, 06 12:35 PM
Hazard and Turn Signal Light Issue 68camrs Electrical & Wiring 2 Jan 5th, 06 01:47 PM
Turn Signal Fuse Blowing DeeGee Electrical & Wiring 9 Dec 30th, 05 12:44 PM
Turn signal fuse blows in start mode BowtieBill Electrical & Wiring 3 Aug 17th, 04 05:00 PM
Tail Light Short & Turn Signal Switch KED67 Electrical & Wiring 3 Jun 25th, 01 09:40 AM
