CS-130 alternator recommendation - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 29th, 06, 09:24 PM Thread Starter
I need the correct CS-130 alternator for the GM serpentine belt setup. The alternator I bought has the bolt holes in the wrong locations for the GM bracket. I am looking for the correct part number for the three wire CS-130 alternator for that GM serpentine belt setup. Any help? Thanks.
68 RS 302 is offline
post #2 of 5 (permalink) Old Sep 5th, 06, 08:12 PM
scblucam's Avatar
Re: CS-130 alternator recommendation
Is the alternator "clocked" correctly? You can remove the bolts connecting the casing halves, pull them apart slightly and rotate 90 degrees and it may fit. I have bought the so called correct part number many times and had to reclock it. Don't pull the halves any further apart than necessary or the brushes will fall out.
scblucam is offline
post #3 of 5 (permalink) Old Sep 6th, 06, 09:37 AM Thread Starter
I really had bought the wrong alternator. The mounting holes didn't line up with the mounting bracket at all. I found the correct part number and I picked up the alternator but as you said I have to turn the back half of the alternator about 90 degrees. Thanks for your help though.
post #4 of 5 (permalink) Old Sep 7th, 06, 10:54 AM
Carl
Take a look at my website. I believe that the mounting lug locations are correct for LT-1 style serpentine use. There is also information in the technical section on alternator conversions that has the Autozone part numbers.
CarlC is offline
post #5 of 5 (permalink) Old Sep 10th, 06, 08:09 PM
BonzoHansen's Avatar
For reference, I had to clock my 130 in order to clear tall valve covers. The charging post hit. I am using a 3rd gen serp setup.
TC Member #13
BonzoHansen is offline
Output Wiring? CS 130 railing68 Electrical & Wiring 7 Aug 2nd, 06 03:07 AM
LS1 into a 68 chickenman97 Camaro Tech 8 Nov 4th, 05 01:40 PM
