69 Headlight Switch - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 3rd, 06, 07:35 PM Thread Starter
69 Headlight Switch
Is there anyone with a wiring diagram for a 69 camaro headlight switch. I have the old harness but it's not of much help considering theres some wires missing. I think I have the terminals in the rigth spot for the most part but the only thing that works when i pull the switch all the way out are the parking lights. No gauges taillights or nothing. Also, I read in an old thread or something that there is supposed to be a ground wire going from the headlight switch to a proper ground. If so, where on the switch does the wire connect to? Im sure I have more questions but those are the biggest problems to me right now. Any help is appreciated.
377camaro is offline
post #2 of 4 (permalink) Old Sep 4th, 06, 07:37 PM Thread Starter
Re: 69 Headlight Switch
Alright, got all the above problems solved except I am left with one more. When I turn the taillights on, all the bulbs turn on. When I hit the brakes, it doesn't light up, it just stays the same. Now, when I turn the lights on, it turns off. Can anybody relate to this or help me.?
post #3 of 4 (permalink) Old Sep 5th, 06, 12:49 AM
madmax87's Avatar
Yes on a 69 the headlamp sw does have a ground strap assy for it. Go to Classic Industries.com and lookup p/n 3937657. It goes around your sw and then the wire connects to the underside of the dash. Make sure to clean the paint off or use a star washer under it. It sounds like your problems are ground related, but check your brake sw by your pedal to make sure it's activating ( the little plastic sw). If you have a meter, I would suggest ohming it out to make sure it is changing states when being depressed. Also make sure your rear wiring harness is grounded. There should be a black wire around the trunk latch assy that gets mounted to the latch support. It needs to be on or you'll get all kinds of weird problems.
madmax87 is offline
post #4 of 4 (permalink) Old Sep 6th, 06, 11:23 PM Thread Starter
Cool man, thanks for the help.
Mounting headlight switch softail02 Interiors 2 Mar 10th, 06 08:33 AM
69 RS Headlight Switch secondtime z Interiors 1 Jan 21st, 06 04:00 PM
69 Headlight Bezel Color on SS ??? Buildinga55 Body Shop 2 Nov 20th, 05 08:33 AM
Wiper switch grounding, heads up TC Codi Electrical & Wiring 0 Jul 5th, 05 10:29 AM
Headlight Switch Opinions dschribs Electrical & Wiring 3 Jul 31st, 03 09:26 AM
