starter wires - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 8th, 06, 04:10 PM Thread Starter
Paul
starter wires
Hi there! Anyone have pictures of the routing of the starter wires for a '69? Especially the wires off the solenoid because its pretty close to the headers. And do I need to run my yellow wire if i'm running MSD 8360 (dist) and 8223 (coil)? Thanks again in advance. paul.
69rszee is offline
post #2 of 10 (permalink) Old Sep 8th, 06, 05:36 PM
Jerry R.
jr68's Avatar
Re: starter wires
I used a type of flexible metal conduit to protect my wire from the header heat ;
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #3 of 10 (permalink) Old Sep 8th, 06, 07:52 PM Thread Starter
Paul
Re: starter wires
This is a great picture. Do you have a shot where it's held down on the firewall. Great idea of using a metal flex tubing for the wire. Thanks paul.
69rszee is offline
post #4 of 10 (permalink) Old Sep 8th, 06, 08:27 PM
Re: starter wires
Here's a couple pics of clicks very original 69 starter wires, and a blowup of the pass side of my firewall showing thre harness routing
ID:	1418   Click image for larger version
ID:	1419   Click image for larger version
post #5 of 10 (permalink) Old Sep 9th, 06, 03:16 PM Thread Starter
Paul
Re: starter wires
Thanks again for the great pictures, paul.
69rszee is offline
post #6 of 10 (permalink) Old Sep 9th, 06, 04:06 PM
madmax87's Avatar
Re: starter wires
Paul, I don't think at least on both of my 69's, that the starter harness runs thru the wire gutter like Jim's pic shows. Maybe different on a 68. There just not long enough. They come straight back from starter, clip to bellhousing bolt and then run over top of bellhousing and come up by wiper motor. If yours are long enough, I would run thru gutter like Jim's pic shows. I'll be under car tomorrow if you want some pics of it.
madmax87 is offline
post #7 of 10 (permalink) Old Sep 10th, 06, 12:53 AM Thread Starter
Paul
Re: starter wires
madmax87, I don't mind seeing your pictures if it's no trouble. I want to see what my options are. Thanks to all of you for the info. received. I'm getting closer on getting my dream back on the street again.
69rszee is offline
post #8 of 10 (permalink) Old Sep 10th, 06, 05:25 PM
madmax87's Avatar
Re: starter wires
My apologies 1st. The harness does run thru the gutter like Jim's pic show. My one car didn't have the gutter but after just re-doing my Z, I was able to put it in the gutter and it fits fine. It also has a ring clip attached to the harness that mounts to the bellhousing bolt. My under car pics today really don't show anything because the headers are in the way, but here is a pic during my engine install of how I ran the wires.
madmax87 is offline
post #9 of 10 (permalink) Old Sep 10th, 06, 07:25 PM
jerry
Re: starter wires
I ran my starter wires through a cloth type heat sleeve I found at summit racing, they sell many different brands,it's similar to what's used on spark plug boots. I used one of their starter heat shields too.I also cut the wires about a foot back and installed a weather pack plug where it would be hidden behind the motor so I don't have to mess with those small solenoid nuts. I can just unplug the wires and they come out and go in already atached to the solenoid
jerry67 is offline
post #10 of 10 (permalink) Old Sep 11th, 06, 12:10 AM Thread Starter
Paul
Re: starter wires
Thanks guys! You've been so helpful. paul.
69rszee is offline
Starter Wires AJL69 Electrical & Wiring 3 Jul 26th, 05 07:47 PM
68 starter wires cohiba1 Electrical & Wiring 2 Apr 18th, 05 09:44 AM
69 camaro starter wires namz111 Troubleshooting 15 Apr 7th, 05 08:16 PM
Starter Tech JimM Electrical & Wiring 2 Sep 21st, 04 10:41 AM
Starter Wires Dobek Tech 2000 4 Jun 11th, 01 06:08 PM
