Ignition steering column diagram - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 11th, 06, 01:27 PM Thread Starter
I recently had one of the wires burn up in my 69 camaro .I think it is one of the ignition wires, but I'm not sure what the wire does or its color. the wires that are next to it are green, brown, red, purple, and pink. I only know that the purple wire goes to the starter, but the others I'm not sure where they go. I'm thinking I'm going to have to replace all of them, because I felt my alternator this morning ,and it was warm, so I think I might have a short some where.
Bjnko69 is offline
post #2 of 2 (permalink) Old Sep 12th, 06, 02:25 AM
Re: Ignition steering column diagram
First disconnect the battery and leave it disconnected. Melted wires are a bad thing , and thats how a fire can get started. I don't have a 69 diagram, but in later yrs there are 2 12g reds, one feeds the starter, the other everything else. Could also be a 12g orange and a 20g brown w/ white strip. Try tracing the burnt wire back to get a color. You also might want to check to see if the fusible links are in place, these protect the wiring before the fuse box, IGN switch and headlight switch.
Greg U
undee72Z is offline
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 09:48 PM
67 camaro steering column 67rpoz22 Brakes, Suspension & Steering 5 Mar 21st, 06 06:00 PM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 06:32 PM
69 Steering Column Rebuild paulm Interiors 13 May 10th, 02 03:32 PM
