More 67 RS headlight woes... - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 18th, 06, 10:11 PM Thread Starter
Unhappy More 67 RS headlight woes...
I posted a couple of weeks ago after I fried the light wiring harness on my 67 RS/SS. I bought a new Factory Fit wiring harness, replaced the circuit breaker and all three relays. I also have new aftermarket motors that were installed with the previous attempt to get these things working. Additionally, I went out of my way to scrape and clean all terminals and ground connections. Hooked everything up tonight and gave it a try. The first time I tried it the doors opened but the headlights would not come on. I could not get them to close with the ignition in both the "on" and "off" positions. I checked all of my connections to make sure they were tight, looked under the dash for any obvious loose wires or blown fuses to no avail. Then something kind of stupid happened - I blew the horn a couple of times to test that, since I had also installed new horns to get that working. It blew fine, and suddenly my headlights came on. I cycled them on and off a few times, and each time the doors opened and closed like they should. I even tested their functionality with the ignition switch in both positions, and all seemed well. I then disconnected the positive on the battery and installed the alternator belt, which I had left off while testing. Reinstalled the positive cable, AND NOW THE LIGHTS AND DOOR MOTORS DON'T WORK AGAIN! Doors are stuck in the open position and no headlights. Everything else works - signal lights, dash and courtesy lights, guages, horn, etc. I'm at the end of my rope here! I'm starting to suspect that I have an issue with my headlight switch or ignition switch, or perhaps the diode on the brown wire off the ign switch (which I could not find).
Does anyone have any ideas on thing to check?
Thanks in advance!
RSSSfanatic is offline
post #2 of 4 (permalink) Old Sep 19th, 06, 04:50 AM
Re: More 67 RS headlight woes...
Its the alternator belt!
Run a separate ground wire from the headlamp/motor circuit to the negative battery post.
Using test light probe, check for available voltage from light switch to h/lamp assy.
Everett#2390 is online now
post #3 of 4 (permalink) Old Sep 19th, 06, 05:05 AM
Smile Re: More 67 RS headlight woes...
Tom,
This is probably not helpful...Where did you connect the heavy red wire from you're new harness, to the junction block on the pass side?
I agree with Everett that a bad ground is likely, but also I'd jumper the red wire from the junction block direct to the battery to test that that wire isn't corroded in the terminal.
Or maybe you just have to honk your horn before you turn on the lights!!!
His and Hers Marina blue 67's
67FamilyFun is offline
post #4 of 4 (permalink) Old Sep 20th, 06, 05:42 AM Thread Starter
Thumbs up Re: More 67 RS headlight woes...
Well, I figured it out - and it wasn't the alternator belt!
My first hint was when I noticed that the headlights would come on with the high beams, and the doors opened and closed properly. I recall reading somewhere that the lights themselves have to be working in order for the doors to close. So at this point I thought it would be a good idea to check the dimmer switch. I had power to the low beam circuit at this point (tan wire), so then I checked it under the hood. No juice, so this pointed to the harness connection at the junction block on the firewall. I wiggled this, and sure enough, they came on. Pushed the connector in a little tighter, and now everything works perfectly! On to the brake system....
thanks for the help, everyone!
67 rs-ignition removal/tip on headlight wiring 67RS383 Electrical & Wiring 3 Apr 3rd, 10 07:17 AM
67 headlight bezels fitting issues 67ragtp Body Shop 4 Jun 22nd, 06 11:04 PM
67 rs headlight probs. Mcox Electrical & Wiring 2 Nov 20th, 05 12:12 PM
67 RS Headlight Issues!!! jay'srs/ss Camaro Tech 7 Sep 23rd, 05 01:19 PM
