67 rs grill or 68 - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 20th, 06, 09:37 PM Thread Starter
Rod
67 rs grill or 68
well i am finally starting to order all my parts for my long awaited dream ,67 rs convert ,and i was thinking that seeing as how i am changing out my intire rs front grill for a comlete grill package from classic ind. so that i dont have to deal with troublesome motors and relays.Heres my question should i stay with the 67 electric style ,or go with the 68 vacume style, due to the problems some have with the electric motors and relays would this make sense .love this site and everyones input.
ragtook riches is offline
post #2 of 8 (permalink) Old Sep 20th, 06, 09:55 PM
Re: 67 rs grill or 68
My '67 RS vert came w/o motors. Wires + relays still there but only 2 small rubber stops (no limit switches at all) on radiator support which look to be '68 issue. I manually slide back the doors they snick back smooth + tight up against the stop. I'm fine with it can't advise you on either vacuum or electric as a choice but if it was mine I'd keep it 1967 on the motors.
schifrin is offline
post #3 of 8 (permalink) Old Sep 20th, 06, 10:02 PM
If you went vacuum, you'd need to drill the 1" hole through the firewall for the vacuum lines to the headlight switch, plus add lines, reservior, check valves, relocate the windshield washer fluid reservoir. The vacuum system also has it's own issues. Ask any of the 68 and 69 guys who are converting to electric...
The original 67 RS motors had issues, but I think the modern ones are much improved. I would think that the modern setup that guys are retrofitting to 68 and 69 cars would fit a 67, as long as you had the right bellcrank setup.
Eric
Eric Kammerer is offline
post #4 of 8 (permalink) Old Sep 21st, 06, 11:19 AM Thread Starter
Rod
after looking into the 68 version abit i think i will stick with my67 style . i did not realize there were as many issues with the vacume type .thanks for the input this realy is a valuable site for trying to get it rite the first time!
post #5 of 8 (permalink) Old Sep 21st, 06, 02:47 PM
Christropher
You'll be spending a lot in all the parts to make the vacuum operated doors function and be correct. Check out the www.retro-electro.net motors. They are MUCH improved over the original electric motors and switches.
Christropher
...in pieces still.
clwilcox33 is offline
post #6 of 8 (permalink) Old Sep 21st, 06, 03:51 PM
Farm Boy's Avatar
The problem with the 67 RS headlight door setup was when the car got wet so did the motors. According to the AIM, Chevrolet added water shields over the top of the motors mid year. An even bigger problem was snow and ice. When the doors iced up the motors would burn up trying to move them.
If you donít drive your car when it is raining or snowing the stock 67 RS setup will last for years.
When I got my 67 the LH motor was not working. I took the motor apart and discovered the armature windings were burned. I purchased some fine "magnet wire" and rewound the motor by hand. My car is an early car and does not have the water shields stapled to the headlight assembly so I covered both motors with large heat shrink caps to keep the water out. Over twenty years have passed since my repair and my electric headlight doors are still working perfect!
If you have most of the original 67 parts in decent condition you should consider using them. If you donít have the original motors, or they are beyond repair, then go with the aftermarket electric system.
Farm Boy is offline
post #7 of 8 (permalink) Old Sep 21st, 06, 04:09 PM
Christropher
The other main problem with the 67s, is the design of the limit switch setup. If the clutches on the motor don't make the doors hit the limit switch hard enough to depress the button, then the motor will keep on running and burn itself out. Some of the newer setups, like the one from Retro I posted above, does away with the limit switch setup and provides a lot sturdier motor that's also completely encased from the weather.
Christropher
...in pieces still.
post #8 of 8 (permalink) Old Sep 21st, 06, 05:59 PM
Paul
I got my '67 RS headlights up and running and agree that each system has its own issues. IMO, I would keep the '67 electric.
My brother had a '69 RS and we always had trouble with his headlight doors.
Both systems are really cool but neither is perfect
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
68 RS Grill and Trim Restoration tim68rsss Body Shop 1 Jul 21st, 06 09:08 AM
67 RS Grill question Kelly Burns Body Shop 7 Feb 21st, 06 11:48 AM
68 RS Grill and Trim Resto tim68rsss Restoration Corner 2 Feb 21st, 06 09:41 AM
AC Centers in 67 68 the same? Joe Harrison Interiors 4 Feb 5th, 06 08:48 AM
67 cowl on 68 balljoint Body Shop 7 Nov 24th, 05 06:25 AM
